Camber Bolts Installation
Im going to buy some eibach camber bolts.
is there anything i need to know about them before installing them?
Which bolt on the strut does the camber bolt replace?
Theres two bolts from the strut to knuckle. Which bolt do i remove and replace it with the camber bolt?
any positive/negative feedback?
thanks guys.
i need as much info as possible seeing that ill be doing this tomm or wednesday.
thanks guys.
I do not recomment camber bolts, no matter what anyone says. If you get them, you'd better be willing to check them on a weekly basis to make sure they're tight...I've seen too many camber bolts shift when you hit a big bump or pothole and throw the whole camber off (which, in turn, throws the toe/alignment off). I've also seen them break. Remember, since they are offset, they are NOT as strong as the OEM bolts.
If camber is that important to you, get plates.
btw, why are you installing these and what camber are you planning to run?
Originally Posted by wikidminds
im on tein s-techs. should i be worried about cambering and uneven tire wear problems??
Camber plates...the only company that I know of that makes them for the 5th gen is Stillen, but might want to check in the 4th gen forums to see if anyone else makes them. They run about $400.
Originally Posted by irish44j
no, not likely. Rear camber won't change, since you ahve a beam axle. I doubt you'll have any serious wear problems if your tire pressures are correct.
Jae
Originally Posted by ThurzNite
I thought plates were pretty straightforward install.. but I saw 1 pretty screwed up install where they ended up drilling a buncha holes in the towers. \Jae
Originally Posted by 97SEdriver
I have heard the opposite, that camber plates put more stress on things because of their location and are more finicky to keep correctly adjusted. I'll bite on this one....you know where I am getting my information from (phillyscca) where is yours coming from?
How could they "put more stress on things" exactly?
The bottom line with the bolts is that, if not checked often, they can come out of adjustment easily if they rotate in the hole. Secondly, because they are only 1/2 as thick as OEM bolts (est.) at the offset location, they are inherently weaker.
No chance I'm going to replace suspension parts with parts that are not as strong!
info from SCCA is irrelevant IMO, since typically they are referring to often-tracked/autocrossed cars, where the owners are continually checking their suspension to make sure things are tight, in good shape, etc on a weekly or frequent basis......not guys who are driving around streets all the time, hitting potholes, etc etc...and may not look at their suspension for months at a time.
My information is coming....from the fact that I HAVE camber plates. I've had no trouble keeping them adjusted. When tightened they don't move at all.
http://forums.maxima.org/showpost.ph...3&postcount=28
um....there is no reason to be drilling anything when installing camber plates
Jae
Exactly! Which's why the install was messed up. Apparently, the installers didn't think of rotating the plate so the 3 bolts line up. Instead they lined up 2, and drilled a hole for the 3rd.
Jae
Jae
I'm guessing you haven't seen this or just don't agree with it then?
My plates have taken a beating already - these terrible roads, multiple autocross events, etc....and I have had no problems with them shifting, rattling, or anything else.
As to camber bolts...
http://forums.maxima.org/showthread....+bolt+broke%22
note in this one that Matt Blehm, our esteemed handling guru, does not appear to be a fan of them either:
http://forums.maxima.org/showthread....camber+bolt%22
note post 6 on this one:
though in defense of the bolts, our "other" handling guru, Brian (BEJAY) uses both plate AND bolts.....though I'm sure he's playing with his suspension on a DAILY basis and would notice any problems.
After I posted I realized something I left out, the phillyscca guys were almost constantly messing with their camber, some guys ran different at each event. So maybe those guys were having problems because of their constant adjustments....who knows. Good bolts, just like good plates should work fine.
Originally Posted by DAVE Sz
aren't the tabs on the camber bolt washers there to prevent the bolts from turning from bumps? It's not like the tabs are in there lightly, they are jammed in there.
lowpost99
Oct 26, 2025 06:53 PM
The Wizard
24
Oct 1, 2015 08:47 PM
ag90fox
Sep 9, 2015 12:22 PM
