trunk NOT OPENING :(
Old Jun 22, 2001 | 09:28 PM
tunedup's Avatar
today my girl was sitting on my trunk and then late i tried opening and no go.
Is there any possible way to open the trunk
when i press the trunk release button i hear the clunking noise that engages the locks so i know the mechanism is still working
any help would b appreciated.
Old Jun 22, 2001 | 09:42 PM
deezo's Avatar
This was happening with my trunk yesterday and it happened to be that the humidity was making the rubber stick to the trunk. I just wiped the stripping down with a little WD40.
Did you try to open it with the key?
Old Jun 22, 2001 | 10:45 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Are you in valet mode? Open your trunk with the key and play with the switch (look down). Close your trunk and try opening it again.
Old Jun 23, 2001 | 11:06 AM
nizmolee's Avatar
On the 4th gen maxima, there is a safety latch so no one can open the trunk with the remote or push button near the drivers side. You best bet is to open the trunk with the key, and when you open the trunk look to the inside of the trunk and you will see a little latch where you can make it click up and down. click it up so you will be able to make the trunk open with the remote. (the latch is where the metal pieces connect when you open and close the trunk.. hope this helps. bro good LUCK!
Old Jun 23, 2001 | 03:07 PM
The_quorum's Avatar
Well if all of that doesn't work...
you can always drive down my street and see if it pops open on it's own like mine does.
(Do check the switch.)
Old Jun 23, 2001 | 08:17 PM
Eric L.'s Avatar
Did you try unlocking it with the key and pulling up the lid? If it is stuck you can always reach in through the ski passthrough on the backseat and push it open.
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
mrgooch
Sep 21, 2015 08:43 PM
