Paint Discussion:
Old Aug 30, 2006 | 08:20 AM
MDeezy's Avatar
Paint Discussion:
I’m doing a lot of reading about automotive painting. A few questions are starting to surface in my head. I remember a few other members are interested in painting to I figured I’d post this here and hopefully a nice informative discussion can arise.
So far I see that there are different types of paints, primers, and clear. Enamel Lacquer and Urethane. Out front bumpers for example are poly-urethane. Doesn’t this mean that the urethane primer/paint/clear should be used? Or the lacquer could be used also as long as flex agent is added to both to allow for flexibility.
I also know the paint is reduced down with a thinner/reducer. Different automotive company reduces it down by different amounts. Does anyone know the general amount the paint is reduced down by? Or even better Good ratio to mix the paint down?
I also noticed the sticker under the hood of my car that specifies this car has a hard clear coat.
Both 2 part urethane primer and lacquer primer are both very popular. The 2 part urethane primer has a higher build, requires less coats, is more flexible, and has better adhesion properties. The acrylic lacquer primer is very popular because it dries very quickly, easiest to sand, and doesn't need to be mixed
Just found that so I guess I answered my own question there.
Additional Info:
I also learned that Enamel lacquer Paint is recommended to be used with a 1.4 tip size on a gun. Urethane 2.0 is recommended.
Old Aug 30, 2006 | 09:23 AM
NisMoN00B's Avatar
+Cru OG
Here's a good link for mixing ratios : http://www.sherwin-automotive.com/he...xing_ratio.cfm
Old Aug 30, 2006 | 07:47 PM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
That is completely based on the brand and type of paint. Each manufacturer will give you different instructions and ratios per use/type/etc.
Old Aug 31, 2006 | 05:10 AM
nupe500's Avatar
Jedi Knight
also check out this link: http://autobodystore.com/forum/index.php
great autobody forum...lots of info
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
