How do I repair curb rash?
Old Aug 31, 2006 | 09:54 AM
phenryiv1's Avatar
Mod her. Ate her.
How do I repair curb rash? My Spec and the Maxima both came with rims with minor curb rash. I plan to refinish the Spec rims this winter. What process or product should be used to smooth out the curb rash before painting?
Old Aug 31, 2006 | 10:16 AM
Nissan 6's Avatar
This is probably one of the best guides to http://www.bmwtips.com/tipsntricks/w...uff-repair.htm
Old Sep 6, 2006 | 09:59 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
From autopia:
http://www.guidetodetailing.com/arti...p?articleId=30
Old Sep 6, 2006 | 10:23 AM
jonmandude's Avatar
Or you can contact Wheels America. They do repairs of all rims...and overnight. I once had them repair a rim when I literally took off 4 inches of the bead from hitting a curb. They repaired it overnight for about $100. They are located in Duncanville, Texas just outside of Dallas. They can do anything, they even widen stock rims. There may also be rim repair places near you, check the phone book.
Old Sep 6, 2006 | 10:26 AM
phenryiv1's Avatar
Mod her. Ate her.
Any ideas on strraightening bent rims? The inner rim/lip is bent on some stockers...
Old Sep 7, 2006 | 09:08 AM
jonmandude's Avatar
Again, Wheels America or any local rim repair shop can do it. The question is is it worth it? With internet rim prices only being generally about $150-$200 per rim is it worth spending the $100-$125 to fix one? Now if your buying high quality rims (the Nismo rims I want are $450 each) then it is definitely worth it.
Old Sep 7, 2006 | 10:58 AM
phenryiv1's Avatar
Mod her. Ate her.
I was more looking for a DIY solution. I the rims are not worth putting money into them, but I don't mind some elbow grease.
Old Sep 7, 2006 | 01:05 PM
X-Vert's Avatar
I believe wheel shops heat the rims up and bang them out... not sure, just guessing.
If you wanta DIY, just take a mallet and try to bang it out yourself.
Old Sep 7, 2006 | 01:35 PM
jonmandude's Avatar
I don't know of any DIY method for straightening rims. With a lot of luck you "may" get them less bent but you will not get them true without proper tooling and a balancer
Old Sep 8, 2006 | 07:27 AM
maxima1380's Avatar
There are numerous rim shops around. They repair the rash and bends.
mkaresh
Mar 12, 2018 06:48 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
MichMaxFan
Sep 30, 2015 09:18 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
