Custom CAI for S/C?
bypass valve isn't going to do anything on a 5 inch pipe design.
why? u need enough room for the "water" to travel up enough to create the vaccum needed to open then bypass valve.
phyics just doesn't play that great of a role with a 5 inch pipe, water will suck into it if you that valve .. cuz the blower will be sucking very fast at that close of a range...
imho. forget the bypass. and the reactive.
just get a nice k&n filter and maybe a velocity stack. but the VS really won't do much cuz the air will just be spinning anyway once it gets into the blower.
So those Ractive filters are garbage? You recommend anything besides a K&N? HKS? Greddy? etc?
Maybe, I'll get just a nice filter that drops into the fender, or lower...
Thanks.
Just a piece together job
Just got some PVC pipe from Home Depot and a K&N conical airfilter. Cut up the PVC to make it fit the where you want it to fit in the passanger side fenderwell. Lots of custom work but I don't have better instructions than that to tell you how to do it.
Originally posted by Screaminfast
Anyone have one, and want to share some ideas? I want to maybe use a RACtive filter, and an AEM bypass in there. Not sure exactly where to go from there? Anyone know the specs?
Thanks.
-Mike
Thanks.
-Mike
Re: Just a piece together job
Re: Re: Just a piece together job
I dont want it to be mad ghetto. I want it to look like a professional CAI. I wonder how much it would be to have something done.
Re: Re: Re: Just a piece together job
Originally posted by OgreDave
I posted pics of my Custom CAI cuz some members were requesting it.. this was about a week ago. Do a search? Its like 7:30am here and im tired/lazy..
The search function completely sucks. I searched for everything possible. It said no results. Maybe you can find it. Dont waste your time though, just let me know when you get a chance. Thanks.
Re: Re: Re: Re: Just a piece together job
http://shell.exo.com/~mman/Maxima/
The pics yer interested in are 20 and up. (a whole 4?) .. if anything is unclear, let me know, ill take more pics. I promised to take pics that nite, slacked off, took pics the next nite.. (work days) .. and takin pics at nite is hard in a dimly lit garage.
Hope it helps.
[EDIT] .. the site is currently down, but itll be back ASAP, just try it once in a while or something. C&W havin problems in souther cali today. Sucks a$$.
Re: Re: Re: Re: Re: Re: Just a piece together job
PVC will melt, won't it?
i'm trying to get some ABS plastic
or do what skimax did.
aluminum.
aluminum.
How did you get access to the inner fender there? You probably ran the pipe, then put the filter on underneath? If thats true, I'm guessing that it is a hard thing to remove and put back on...heh
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
carid
Sep 17, 2015 05:00 AM
