A/C smells like dog sh!t
Old Oct 3, 2006 | 06:18 AM
THX's Avatar
THX
Hallelujah
A/C smells like dog ****
Bought a used 2k, it runs well but there was an odor inside, of dog poop. I cleaned the interior for a couple of hours over the weekend and wiped down the seats with some leather cleaner. Added an air freshener to mask what little smell was left.
Problem is the A/C still spits out the same crappy odor. Anyone else deal with something like this? Should I change the air filter or is there another solution?
Old Oct 3, 2006 | 06:25 AM
Greeny's Avatar
¯\(°_o)/¯
Spray some lysol in the fresh air intake vents....
Old Oct 3, 2006 | 06:27 AM
naxray's Avatar
MY 2k did not have the in cabin air filter installed as it was an option that year. Installing it helped with the A/C smell. I also cleaned all the leaves out of the area prior to installing.
Old Oct 3, 2006 | 07:04 AM
CanadianMoFo's Avatar
There is an A/C cleaning product made specifically to deal with A/C funk. While the A/C is running you spray it into the interior air intake.
CM
Old Oct 3, 2006 | 09:14 AM
Black Maxima
Are you sure the previous owner didn't leave a stash in the air vents?
Old Oct 3, 2006 | 10:53 AM
Hectic's Avatar
yeah..mostly maui wowie, but it had some labrador in it
Old Oct 3, 2006 | 11:52 AM
loverholic's Avatar
iAMIXAM!
lol...... thats messed up...
Old Oct 3, 2006 | 12:26 PM
THX's Avatar
THX
Hallelujah
is the air filter by the driver's side feet?
Old Oct 3, 2006 | 12:32 PM
naxray's Avatar
behind glove box
http://www.innerbean.com/housecor/cabin_filter.html
Old Oct 3, 2006 | 12:38 PM
THX's Avatar
THX
Hallelujah
sweet, thanks for the info
Old Oct 4, 2006 | 08:13 PM
2LEET4U's Avatar
that happened to a cousin of mine. but the reason why his used car smelled was because the previous owner ran over a cat or dog and some of its hair and guts were stuck under the car and lodged into the engine....
If it were a dog, poor puppy.... if it were a cat,
Old Oct 5, 2006 | 05:24 AM
04BlackMaxx's Avatar
Change the in cabin air filter
Old Oct 5, 2006 | 06:13 AM
Glude's Avatar
lol, since when does a stash smell like dog ****? On a similar note I found a dead mouse under my shifter in my prelude way back in the day. I had a HORRIBLE smell for a few months then when I went to install an STS I found the answer to the smell.
Old Oct 5, 2006 | 06:44 AM
Shannon and Ian's Avatar
I hope a mouse did not climb into the fan like it did in my NX and die. After a week of cabbage smell, I decided to take the blower out and walla, there was a dead mouse. EEEEW!
Old Oct 5, 2006 | 05:09 PM
E-CARP's Avatar
Try Fabreez sprayed into the inside air intake, under the right side of the dash, with the a/c running, and set to re-circulate. It works like a charm, and don't let your rottie crap in the outside vent anymore, even if he does like the warm hood to lay on!
Old Oct 5, 2006 | 07:16 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
They sell a special deodorizer at AutoZone that sprays pepper mint like spray. You put it right under the glove box, turn on the AC on MAX cool with the recirc on and then trigger the aerosol can and let the stuff spray onto the evaporator. Alot of time the mildue will collect on the evaporator and it smells really bad.... this should work pretty good. The Deodorizer also works for cigar smell pretty good.
Old Oct 6, 2006 | 03:33 PM
Jez, thats you? Wow, it's Ian from the list. Whats good?
Old Oct 6, 2006 | 03:47 PM
Jeff92se's Avatar
I'm needing a caw
I used Ozium in the fashion that blackbird described. Worked well. You spray alot of it into the intakes w/ the AC going full blast. Then shut the door and let it recirc for 10 min. Periodically reblasting the area.
Old Oct 7, 2006 | 08:20 PM
Willy Willy's Avatar
thanks for the link maxray. i gotta do this too. my max is smelling funky.
Old Oct 8, 2006 | 09:41 AM
PM me some time, catch up with the times... Its been about what 10 years ? Glad to see you still got the Max and the NX after all those years.
Old Oct 22, 2006 | 11:39 AM
bcambell23's Avatar
I tried the technique recommended by e-carb and blackbird. Although I used lysol, then ozium. It worked great. But then again, I was only battling cigarette smoke and not some dog/cat funk from the netherworld.
Old Oct 27, 2006 | 10:41 AM
zywiec21's Avatar
my maxima smells like ****, i'll try lysol over the weekend.
Old Oct 27, 2006 | 11:45 AM
Vil's Avatar
Vil
I had some luck with Febreeze, when I first got my max there was some nasty rotten-eggs smell coming out of the A/C.. sprayed some Febreeze and it smells just fine now.
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
carid
Sep 17, 2015 05:00 AM
EdRomo86
Sep 12, 2015 07:49 PM
