Found this hiding in my garage...
Old Nov 8, 2006 | 08:46 PM
shadyonedeath's Avatar
I dug this Analog Ohmmeter, looks brand new.
Anyways, im planning on checking my knock sensor's worthiness.
How would one use this puppy? Has alot of settings, dials, and sockets.
I'm not even sure if it works, how could i test it?
Old Nov 8, 2006 | 08:54 PM
Hoooper
easy to test an ohm meter. the place you plug them in: black goes to the ground (com) and red goes the the one with an oh symbol(the one with three symbols and no DC around it) before you test to see if it works, you have to move the dial from off to one of the ohm settings (looks like 5 of them, they say RX ___ and you just have to find which one gives the best answer) then to test just touch the red and black together
Old Nov 8, 2006 | 09:03 PM
I touched them together, nothing happened.
Any other way to test?
Old Nov 8, 2006 | 09:26 PM
Hoooper
there should be a battery in it somewhere and a fuse, check them
Old Nov 8, 2006 | 09:41 PM
Theres a 9volt and AA battery, i just replaced them, still no readings. I think its shot, nvm.
Thanks hooper.
Old Nov 9, 2006 | 09:08 AM
ThurzNite's Avatar
Almost looks like a 1st generation RadioShack multi-meter. Cool find. Wonder if it's worth anything on ebay.
Sucks about your knock sensor. Did you replace it?
Jae
Old Nov 9, 2006 | 11:38 AM
No, didnt replace it. I just read about losing low-end power when it dies.
I did remove it to clean the contact point to the engine block, but im not sure if i tightened it enough. I heard it had to be "just" right enough to work properly.
So i guess ill tighten it a lil bit more, see if it improves.
Oh yea, ohmmeter is dead. Doesnt move for anything.
Old Nov 9, 2006 | 03:42 PM
Hoooper
sorry to hear that, always sad to see a classic bite the dust
Old Nov 10, 2006 | 01:15 AM
MorpheusZero's Avatar
Yeah that's too bad, that thing's badass.
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
