Sanding Calipers Before Painting?????
Old Feb 1, 2007 | 12:46 PM
2LEET4U's Avatar
Guys, is it recommend to sand down the OEM calipers before painting them.
I have some Caliper paint i just from a local Auto store and the instructions do not mention anything about sanding the caliper down.
For those of you who have painted calipers, what do you recommend?
Old Feb 1, 2007 | 03:09 PM
Nismo's Avatar
unless they are corroded or something then just wire brush them and spray them down with brake cleaner.
Old Feb 1, 2007 | 10:09 PM
!PrjctMax!'s Avatar
+1, exactly what I did on my buddies RSX
Old Feb 1, 2007 | 10:13 PM
2LEET4U's Avatar
cool thanks guys.
Old Feb 2, 2007 | 04:14 AM
jltibbs's Avatar
i used a dremel to get rust, brake dust and road grime off of mine. when you first spray them off with brake cleaner it looks ok. but once you put that wire tip on a dremel and go at it, it makes a world of difference
Old Feb 2, 2007 | 07:25 PM
00MaxSE's Avatar
Pointy Elbows
Didn't have a dremel, so I used a drill. Sanded all the rust off and cleaned up with some mineral spirits prior to applying primer.
Old Feb 3, 2007 | 03:50 AM
jltibbs's Avatar
nice. if people would just take the extra time and do it right
Old Feb 5, 2007 | 12:20 AM
2LEET4U's Avatar
Heeehahaha!!
i did guys... check it out!!!!
I used caliper cleaner. my calipers werent that dirty, so i didnt need dremel or sanding paper. I did use a heat gun to speed the drying process. The processs was time consuming since I removed the calipers completely off. So I had to remove the pads, plug the brake fluid and then attach, bleed the brake fluid of air, add a little more brake fluid....UGGHHHHH!!!
But i like the outcome of my work....
Old Feb 5, 2007 | 12:35 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I used a wire brush attachment on my drill to remove surface rust, then used a grinding bit to remove some of the casting marks to "smoothen" the appearance. Once that was done, I sprayed metal surface primer before painting.
Old Feb 6, 2007 | 08:15 PM
NismoFrk's Avatar
looks great! Just be prepared to redo them 2x a year to keep them in top shape....mine wear out every 4 months or so
Old Feb 7, 2007 | 03:20 AM
jltibbs's Avatar
looks really good. IMO i would have gone with silver or blue. but honestly it does look good. just painted mine red a while back.
Old Feb 7, 2007 | 09:37 AM
00MaxSE's Avatar
Pointy Elbows
I did mine 3 years ago and they are holding up well. Just a few small chips. Did you use primer and 2 coats of paint?
Old Feb 9, 2007 | 01:01 PM
bladerunr's Avatar
Don't forget the clear coat.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
