cheapest place for Redline fluids??
Sticky
Check the sticky on maintenance items. It refers you to two places...I ordered from the second place (got 5 liters of MT-90 at $7.75 a bottle with only $5 total for shipping). The shipping is this low because they refer the order to the nearest performance racing store by you (that sells Redline). Mine was OG Racing in Manassas VA (www.ogracing.com).
I just received my 5 qts of MT-90 from www.myoilshop.com. It was $7/qt, got a 10% discount (check the stickies for dealer code), and shipping was under $6. Fast shipment too, only 3 days.
okay maxima guys!! just to let you know that redline is a racing oil and has corressive additives to your tranny. It is made for racing purpose only and not for everyday use! use purple stuff.. otherwise, REdline needs to be changed at least once a year. good luck!!
You better check your facts.Redline Racing Oil is an engine lube intended for race applications and not recommended for everyday use because it does not have the same detergents.
However, we're talking about MT-90 manual tranny fluid. Different product, different properties. It does NOT contain corrosive additives and is OK for normal use per the API "GL-4" service description. The 75W90 viscosity range matches what's required in the owners manual.
Originally posted by Sly
Huh?
However, we're talking about MT-90 manual tranny fluid. Different product, different properties. It does NOT contain corrosive additives and is OK for normal use per the API "GL-4" service description. The 75W90 viscosity range matche what's required in the owners manual.
Huh?
i got my resouces from Creative performance in Garden Grove and St. Andres. both had the same response. anyhow Good luck!
I purchased my Redline Oil from
www.ioportracing.com
Pretty good prices and very fast shipping. You get a volume discount too.
Need help
23
Oct 2, 2015 08:56 AM
