Which Optima battery should I get?
Old Mar 8, 2007 | 07:19 AM
Trilitai's Avatar
Hello! I plan to buy a new Optima battery. So should I get the red or yellow for my 97 Max and why? Can anyone give me the part number also? Thanks!
Old Mar 8, 2007 | 09:16 AM
SilverGLE's Avatar
I'm watching you, boy...
Red top = power for harder starts with a lot of equipment (ie, off road vehicles).
Yellow top = deep cycle, useful for running accessories with the engine off (ie, 1000 W stereos at the drive-in).
Old Mar 8, 2007 | 09:43 AM
00MaxSE's Avatar
Pointy Elbows
If you plan to get aftermarket stereo with subs etc, I'd get the yellow. If not, get the red.
Old Mar 9, 2007 | 03:25 AM
JFP in PA
Red Top, size 35.....................
Old Mar 9, 2007 | 03:52 AM
xx-Marshall-xx's Avatar
kthxbye2u
whats so "hip" about these optima batteries?
Old Mar 9, 2007 | 04:21 AM
00MaxSE's Avatar
Pointy Elbows
If you HAD one you would know.
Old Mar 9, 2007 | 05:27 AM
JFP in PA
They are not "hip"; but they are very long lived (typically 1 ½ to 2 times the life expectancy of a regular lead/acid battery), totally sealed (no corrosion, ever), can be mounted anywhere and in any position (even upside down), and have tremendous deep cycle capability……………………….
Old Mar 9, 2007 | 10:16 AM
Trilitai's Avatar
Which Optima Red should I buy for my 97 Max? I see many different models and what are the difference? 25, 34, 34/78, 34R, 35, 75/25 ... Thanks!
Old Mar 9, 2007 | 11:24 AM
JFP in PA
The 35 fits..............I have one in my 97.
Old Mar 9, 2007 | 05:00 PM
Revs2Hard's Avatar
BARF
I have a Optima red top battery and it has caused me nothing but problems. I plan on getting a odyssey, thats what everyone I know has changed out to in there street cars and full drag cars. check them out I know you wont be disapointed with it- http://www.odysseybatteries.com/
Old Mar 9, 2007 | 05:11 PM
ozzombie13's Avatar
I will eat your children
OPTIMA YellowTop Benefits
* Dual Purpose starting and deep cycling.
* Lasts up to 2 times longer than other batteries.
* Constant performance quality keeping your battery running at the same level even as it's being discharged.
* More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead acid batteries.
* Ideal for seasonal use, fully charged, it can sit unused for up to 12 months at room temperature (or below) and still start a car.
* 15 times more resistant to vibration than other batteries.
* Nonspillable and can mount in almost any position.
why yellow is better. i love mine. i can run the stereo for hours car starts right up. i have d34/78
Old Mar 9, 2007 | 07:02 PM
JFP in PA
Care to enlighten us to "nothing but problems"...........
Old Mar 10, 2007 | 08:09 AM
SmokinMaxSE's Avatar
SmokinMaxSE
One good benefit is Optima's are dry cells, which makes it good against vibration. They can be turned and shaken really good. Hard vibration over time can kill a regular battery. Optima's can be drained and charged multiple times and still perform like new.
Old Mar 10, 2007 | 10:15 PM
wikidminds's Avatar
you should get the blue top marine optima for your maxima......
Old Mar 17, 2007 | 08:40 PM
dko's Avatar
dko
duck and cover
visit your local towing company. they usually have a lot of batteries in good shape just laying around. i got a slightly used yellow top for $20. it's been perfect for the last two years
Old Mar 17, 2007 | 08:54 PM
00MaxSE's Avatar
Pointy Elbows
WOW, $20? That is a deal!
Old Mar 17, 2007 | 11:08 PM
MrGone's Avatar
when you roll your Maxima upside down you don't have to worry about it leaking
and people think they look cool
aside from that, nothing.
Old Mar 17, 2007 | 11:11 PM
MrGone's Avatar
I've had a high enough failure rate with Optima batteries that I will not use them on daily drivers anymore.
Old Mar 17, 2007 | 11:31 PM
D-Bo's Avatar
Droppin logs
yellow top in my dd
Old Mar 18, 2007 | 01:22 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Optima Red Top in both my vehicles, ZERO problems last 2+ years...
Old Mar 18, 2007 | 02:21 AM
JFP in PA
I have four red tops, one is almost 11 years old and just recently passed a load test with flying colors.............................all have been flawless performers, even in sub zero weather................
Old Mar 18, 2007 | 02:48 AM
dko's Avatar
dko
duck and cover
i have to agree. i jumped a friend's f350 turbo diesel without any problems
Old Mar 18, 2007 | 08:00 AM
wikidminds's Avatar
i had a red top in my integra for 6 months then i crashed the integra. i kept the red top in my storage shed for about 1 yr and a half then i got a 4th gen. i put the red top in the 4th gen and it cranked right up. im still running the red top since 2004!!!!
Old Mar 18, 2007 | 09:41 AM
djfrestyl's Avatar
Suspension Yoda
I had a red top for 2.9 years. Crapped out on me, but I got a brand new one with another 3 year warranty for no charge.
Old Mar 18, 2007 | 11:11 AM
MrGone's Avatar
If all of them failed they wouldn't be on the shelves
Old Mar 18, 2007 | 01:05 PM
JFP in PA
I often wonder how many "battery failures" are the result of the fact that most newer cars have constant current drains (ECU, alarm systems, keyless entry systems, audio systems that use battery power to hold station settings, clock time, etc.; cell phones, GPS systems, and so forth) that steadily draw down the battery and cause issues when the car sits for a bit (1-2 weeks), particularly in cold weather. My 97 has had a tendency to drain batteries when left to sit for over three weeks while I was out of the country on business. I ran an elaborate test sequence and determined that all of the battery drains were related to these items. When the car is driven every day, there was never a problem; only when it sat. I cured the problem by using a battery maintainer when the car sits, and the problem has never reoccured. My Porsche also has the same type of problem when it sits, but Porsche is up front about it and provides a maintainer as well as a notch in the bottom of the driver's door for the wires to run thru, and a lighter plug that remains "hot" when the ignition is off so you can plug in the maintainer, close the door and arm the alarm, and the battery is kept in perfect condition while the car sits out the winter.
The more electronic gear we add to these cars, the harder it is on the battery...................
Old Mar 18, 2007 | 11:11 PM
SilverGLE's Avatar
^ Yup... I completely agree. I remember reading somewhere that it's a good idea to simply replace your battery every 3 years or so just to keep from having the "oh, crap, it's dead again" inconvenience. I intend to change my battery (probably to a auto parts store brand like Duralast) out whenever its warranty is nearing the end.
Old Mar 18, 2007 | 11:55 PM
MrGone's Avatar
Most conventional batteries are made in the same factory with different labels slapped on them.
Old Mar 19, 2007 | 10:58 AM
Byteme's Avatar
Old Mar 19, 2007 | 11:31 PM
SilverGLE's Avatar
Good point. I just get whatever's cheapest with the CA's and CCA's I need... In the case of my 94 Camry, the best value was at Wal-Mart...
Old Mar 20, 2007 | 01:21 PM
pimperz2000's Avatar
i've been running yellow tops for 2+ years for my audio with no problems.
Old Mar 20, 2007 | 01:56 PM
00MaxSE's Avatar
Pointy Elbows
That's what I have in my truck. Everstart FTW.
Old Mar 21, 2007 | 12:44 AM
Revs2Hard's Avatar
BARF
I bought this Battery through my work brand new and ever sence it keeps loosing its charge on a monthly basis, It also dies even sooner when it is cold out. thank good I live in a house that the driveway is on a slant because I have had to compression start my car twice just to get it running in the morning. Ever sence I put it in when I turn on any of my accessories all the lights dim and the more I turn on the darker they get untill I rev the car up. I have seen customers come back that have bought a optima and its giving them same problems. Optima wont replace them till they fail the load test which its major BS. Every time I charge it I test my alternator and its fine then I test the battery hopeing it will fail so I can get my money back. Now im buying a odessy, because I called there local dealer and they said if one of there batterys was doing this they would replace it no question asked.
Old Mar 21, 2007 | 06:41 AM
BD44's Avatar
Just get the one suited to what you will be doing the most.
Old Apr 18, 2007 | 06:30 PM
redmayns's Avatar
are they really that much better than regular oens
Old Apr 18, 2007 | 06:54 PM
00MaxSE's Avatar
Pointy Elbows
YES .
Old Apr 18, 2007 | 06:57 PM
MrGone's Avatar
Originally Posted by 00MaxSE
YES .
no .
Old Apr 18, 2007 | 06:59 PM
djfrestyl's Avatar
Suspension Yoda
Maybe so?
Old Apr 18, 2007 | 07:11 PM
00MaxSE's Avatar
Pointy Elbows
no .
Old Apr 18, 2007 | 11:27 PM
Ride2kMax's Avatar
I got the yellow for over 2 years now.
I always leave the car off and turn the radio on.
Its been pretty good with me so i would recommend you that one.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
