Attn: mzmtg "ecu stuff"
Old Jul 9, 2001 | 06:14 AM
Sprint's Avatar
So i pulled my ECU down to see where and what that other pink/blue wire was and for the 97 GXE not sure about the others .. maybe 96/97/98/99 .. its the fuel temp sensor.. but get this.. they are BOTH on the RIGHT HAND SIDE of the screw..
the Speed Sensor wire is the pink/blue wire closet to the screw on the RIGHT HAND side of the screw... the fuel temp sensor is farthest away from the screw and its near two white wires..
I also decided to run the car full cut with no switch and on the 5spd .. the car's RPM will dip below 500 down to 0 RPM when you get off the clutch and will eventually make its way back above 500 RPM .. you can tap the gas a little bit and it will be ok.. I only stalled once, however i am going to watch it for a week and see if its just the ECU trying to retrain it self or if i stall again.
Old Jul 9, 2001 | 07:36 AM
mzmtg's Avatar
Minister of Silly Walks
Good to know. I havent had any problems at all so far...
Well, the only problem is that I havent had the chance to "test" this more than twice
Old Jul 9, 2001 | 07:50 AM
Sprint's Avatar
Another note.. the ECU retards the car after 105 and the car is about i would say 60% power.. at about 110 the car is at 50% power... right before the gas cuts about 117 - 119 .. with the speed sensor cut.. the car is free willing and moves from 100 - 120 with full blast.. now that i have my test pipe i am noticing this much more..
Old Jul 9, 2001 | 08:03 AM
Sonic's Avatar
Uh, oh. Time for me to pull another trick put of my sleeve. Does the car still pull after 120 though?
Old Jul 9, 2001 | 10:11 AM
Sprint's Avatar
pulled right to 127 mph then i ran into traffic.. my cousin said if i had kept on it.. i would have been at 130 no problem.. however.. i don't trust my brakes that well
Old Jul 9, 2001 | 10:12 AM
mzmtg's Avatar
I never noticed that. My car would charge right up to an indicated 117. The fuel would just cut out and throw you forward in the seat...until the speed dropped below the limit and then it would charge right back up.
Old Jul 9, 2001 | 10:15 AM
Sprint's Avatar
well the thing is.. since i have the noisy warpspeed pipe you can hear the hissing sound.. and once i touched 110 the hissing got kinda wierd.. like a loud whine... like the power was going.. but after the wire was cut it didn't do it anymore
Old Jul 9, 2001 | 10:55 AM
BlkStnValyMaxima's Avatar
Aaaaah, Fuel temp sensor. I see, so that's the wire I cute. Ooops. Oh well, I guess that's how we learn. At least I got the right one now. Now I gotta figure out which one the RPM sensor is. My Apexi rev/speed meter is half working.
Old Jul 9, 2001 | 11:01 AM
mzmtg's Avatar
I'm gonna go out late tonight and go for a top speed run. Just gotta pump the tires up to about 40psi and I'll be ready to burn...
Old Jul 9, 2001 | 11:08 AM
Sprint's Avatar
damn.. i tapped it the other day for my nitrous controler.. if you want me to take a pic when i go home let me know..
Old Jul 9, 2001 | 11:21 AM
Yeah, definately i need to find out which one that stupid rpms one is. oh yeah. i got the ingition power right, to turn it on. but it also needs a constant power too so it can remember the settings i put in (i'm assuming anyway). do you know which one is used for that too?
Old Jul 9, 2001 | 11:33 AM
Sprint's Avatar
ok i will try to do that tonite... my constant power comes directly from my battery...
Old Jul 9, 2001 | 02:37 PM
Synki's Avatar
Anyone tried this with a auto? Hmm, maybe i should try this, but after all you guys figure out the bugs. Either that or i'll buy the Apex'i unit and have that remove my limiter.
Old Jul 9, 2001 | 02:43 PM
Sonic's Avatar
Doesn't mzmtg have an auto?
Old Jul 9, 2001 | 07:44 PM
mzmtg's Avatar
yes he does.
Old Jul 10, 2001 | 05:23 AM
mzmtg's Avatar
Well, I got the switch in. I wired in another 20amp switch and mounted it in the coin tray next to my tranny controller. I cleared the MIL and went through the song and dance to clear the TCM codes, what a PITA. So now I have speed when I need it, drivability and no MIL when I dont.
Old Jul 10, 2001 | 05:39 AM
deezo's Avatar
Good going fellas and good luck.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
cruce91
Sep 20, 2015 10:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
