Compression Tester help.
Old Mar 31, 2007 | 08:45 PM
Maximahappy22's Avatar
I got a comp. tester but the directions are confusing... could someone clearly explain to me how to use a comp tester.
Thanks,
Alex
Old Mar 31, 2007 | 08:49 PM
wunfstmax's Avatar
Unplug the coil packs, remove spark plug use adapter in spark plug hole, have someone crank car and record reading.
Old Mar 31, 2007 | 08:51 PM
do i remove all the spark plugs or just the one that im testing?
Old Mar 31, 2007 | 08:54 PM
wunfstmax's Avatar
You can remove all. Also remove fuel pump fuse, and let the car die before cranking the motor to do the test.
Old Mar 31, 2007 | 09:02 PM
k thanks for the help!
aw11power
Oct 10, 2021 04:57 AM
Taino14
Sep 24, 2015 02:51 PM
hozay99
Sep 19, 2015 10:20 PM
