Engine Restore
Old May 20, 2007 | 09:43 AM
Professor's Avatar
Engine Restore
Has anyone Tried this ? Is there any reason why someone should or should not use this ? What are your like or dislikes about this and do you or dont you recommend this . Iam only asking because i just rolled over 116k miles
Old May 20, 2007 | 01:34 PM
Zero Deuce SE's Avatar
If you need something like that in your engine you need some work done to it. There is no liquid cure for a mechanical problem as far as I know.
Old May 20, 2007 | 01:54 PM
natty99's Avatar
^^^dude, what's up with the bold italics?
anyways, I used it in my car around the time I bought it. Drove the car for a while first to get a feel for it (obviously need a baseline to compare to), then added the restore to my oil during an oil change. Never really felt any changes, so who knows if it works. Probably not.
Old May 20, 2007 | 02:33 PM
Bold italics is my style. I believe it's something you use on badly maintained and worn engines.
Old May 20, 2007 | 02:38 PM
James92SE's Avatar
2 VE's are better than one!
I wouldnt use it unless you had a low compression problem in a cylinder or two and wanted a cheapo temporary fix for it. For what it's worth, I've actually read that it works
Old May 20, 2007 | 03:26 PM
MorpheusZero's Avatar
Well, to everyone else it just looks like you're stressing every single word that you say.
My engine has 185k on it now, still running great. Just keep giving it fresh oil and you should be fine.
Old May 20, 2007 | 03:43 PM
Greeny's Avatar
¯\(°_o)/¯
Snake oil.....Stay far away from it and all other so called "engine restore" products in a bottle...
The only thing you need to do is regular oil changes for as long as you own the car...
Old May 20, 2007 | 04:27 PM
Cliff Clavin's Avatar
Way out West
I agree. I don't think it will do any good on a car that is running right. If you have low compression, it might be a decent temporary band-aid.
Like Mr. Bold Italic said, it won't cure an actual mechanical problem.
Old May 20, 2007 | 04:31 PM
wyche89's Avatar
i used that crap on my old pontiac... maybe on my maxima, i cant remember.. but i didnt feel any difference
Old May 20, 2007 | 04:32 PM
D-Bo's Avatar
Droppin logs
Originally Posted by Cliff Clavin
Like Mr. Bold Italic said...
If I type like this will people listen to me?
Old May 20, 2007 | 04:33 PM
The name is Zero Deuce. Instead of worrying about someone's choice of fonts, let's just give the OP some input on his question please. I believe that this stuff is something thick like Lucas oil treatment and will only mask the problems it claims to help.
Old May 20, 2007 | 04:35 PM
Greeny's Avatar
¯\(°_o)/¯
NOOOOOOO,LIKE THIS!!!!
Old May 20, 2007 | 08:00 PM
Professor's Avatar
haha nice comments, i havent used it, i just wanted to know if there is any benifits from it, the car runs fine, i do regular oil changes, i use Penzoil Platinum 5 w 30.
Old May 20, 2007 | 08:21 PM
Listen, as far as everyone else is concerned it's akin to typing in all caps. If you want to you can, but it's annoying, attention grabbing, harder to read, and to most of the members makes you look like an idiot.
I'm just saying...
Old May 22, 2007 | 12:58 PM
bwinter7's Avatar
Back on topic, In my 93 I had pretty loud lifter noise, nothing bad, but annoying. I put that stuff in and it went away. I use it anyway on my 02, but I dont know if I'm doing anything. It cant hurt, but it does work on lifter noise.
Old May 22, 2007 | 01:42 PM
Greeny's Avatar
¯\(°_o)/¯
If you had a 93 SE,then what you were hearing was VTC clack,not lifter noise..
Old May 22, 2007 | 02:02 PM
bwinter7's Avatar
sorry, it was my first car....
Old May 22, 2007 | 08:16 PM
Torgus's Avatar
your style is annoying. i doubt it will be put up with for long...
Old May 23, 2007 | 02:44 AM
Time will tell. It's been done for quite some time now. People are always welcome to ignore my posts.
Old May 29, 2007 | 06:36 AM
suess88's Avatar
Restore
Yes I have used this ..not on my nissan but on my jeep it is amazing under extreme conditions if your engine has cylinder scrapes and scratches it will raise the compression most definately but if it aint broke dont fix it ..its some thick stuff and can clog things on occasion by the way can anyone tell me if my 02 came from the factory with synthetic or standard oil....???
Old May 29, 2007 | 05:20 PM
eyeball's Avatar
Don't waste your money.
Old Jun 1, 2007 | 11:07 PM
D-Bo's Avatar
Droppin logs
Why would we ignore them Mr Bold Italic? I would venture to guess you want the exact opposite.
Old Jun 2, 2007 | 03:58 AM
It doesn't matter what I want. If you want to read my posts, fine. If you don't like my style then keep it moving.
Old Jun 2, 2007 | 01:06 PM
STARR's Avatar
if your questioning the condition of your engine, might as well get a UOA from blackstone http://theoildrop.server101.com/forums/ubbthreads.php
Old Jun 4, 2007 | 08:36 PM
D-Bo's Avatar
Droppin logs
Oh I much prefer to sit here and absorb your so-called style
Old Jun 4, 2007 | 08:48 PM
Madsci's Avatar
I used it in an old truck. Seemed to cut down the oil consumption quite a bit. That may be because it does what it claims to do, or just because it thickens the oil up a bit which tends to help on old worn out motors. My opinion is: if your motor is in bad enough shape for you to be thinking about "restore" in a can, you may as well give it a shot because its probably almost toast anyway.
Old Jun 19, 2007 | 07:12 AM
MHenderson's Avatar
Would not use it unless it was a cheap temporary fix to keep an old beater running. On the max, no way
Old Jul 15, 2007 | 09:57 PM
ashazad's Avatar
it gives people a false sense of security i think
Old Jul 16, 2007 | 10:06 AM
MaximusX's Avatar
you are either or .
Old Jul 16, 2007 | 10:40 AM
ShIft_uR FacE's Avatar
I've used it but no pros or cons that i can tell...so if your engine is running good, let it be.
Old Jul 18, 2007 | 03:17 PM
streetzlegend's Avatar
You guys think this can hurt a turbo somehow?
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
