View Poll Results: What grade of gasoline do you put in your Maxima?
87 Octane
80
11.56%
89 Octane
87
12.57%
92 Octane
213
30.78%
over 92 Octane
303
43.79%
diesel: Are car takes gasoline?
1.30%
Voters: 692. You may not vote on this poll
What brand and grade of gas do you put in your Maxima?
Old Jan 6, 2006 | 02:47 PM
  #41
RockfordMax's Avatar
Back from the dead
93 octane Mobil or Amoco
Old Jan 6, 2006 | 05:57 PM
  #42
Deckdout2's Avatar
Play with my balls
Holy crap talk about coming back from the grave........Glad you found it instead of starting a new post........so sure, I'll play along......93 Octane on Citgo/Exxon/76-BP.
Old Jan 6, 2006 | 06:07 PM
  #43
red-line-racer's Avatar
is it true that useing the expensive gas in any gas station cleans your injectors and gives u more hp because i just think it a bunch of BS
Old Jan 6, 2006 | 08:52 PM
  #44
Fr33way™'s Avatar
Wild for Width
QT Premium Top Tier FTW
Old Jan 6, 2006 | 09:08 PM
  #45
vansskaterfreek's Avatar
the cheapest crap you can buy
Old Jan 6, 2006 | 09:46 PM
  #46
Mass_Media's Avatar
Mass_Media™
92 from chevron or tesoro
Old Jan 6, 2006 | 09:56 PM
  #47
AscendantMax's Avatar
92 from shell, 89 from time to time.
Old Jan 6, 2006 | 10:29 PM
  #48
MrGone's Avatar
Arco
sometimes Chevron or Costco when I forget it's really not that great of a deal.
Old Jan 6, 2006 | 10:42 PM
  #49
mrose120's Avatar
Shell V-power 93
Old Jan 6, 2006 | 11:06 PM
  #50
Nissan 6's Avatar
This thread is five years old just to let everyone know
Old Jan 7, 2006 | 05:41 AM
  #51
blackpaladin67's Avatar
100 octane
We have a new gas over here , they lauched it last month .. Seems to go quite well ..Put two tanks of it in so far. Shell Optimax Extream 100 .
Good ol Auzzie Gasoline.
Old Jan 7, 2006 | 06:33 AM
  #52
maxwannabenow's Avatar
we only have 89 and 93 here so I usually put in 93 or do a half 89 and half 93 to get 91
Old Jan 7, 2006 | 11:25 AM
  #53
Vaudeville Villain's Avatar
93. I only stop at Shell, Chevron, or Mobil.
Old Jan 7, 2006 | 11:36 AM
  #54
Superinc_V6's Avatar
91 on the VQ
  #55
DrKlop's Avatar
Driving is the next best thing
93 - Sunoco & Mobil
I will never use Shell in my Maxima.
I got my injectors clogged the fist time I put it in.
The second time I used Shell my car ran like ****.
After I put it in the third and the final time, I got a bad misfire when I started it the next day.
Old Jan 7, 2006 | 12:17 PM
  #56
konak85's Avatar
Originally Posted by TarHeelMax
I respectfully disagree. Performance is gained when an engine is fed its recommended AKI/RON fuel. Any higher than recommended, and you're wasting your money because the engine is already running the optimal timing program and fuel map and cannot take advantage of a more burn-resistant fuel index. Any lower, and a modern high compression engine will compensate (without knocking) by retarding timing. The VQ, for example, is one such engine with digital knock management. It won't ping if you feed it 86 octane, but you sure as heck aren't getting optimal performance out of the engine. Whether this is noticeable or worth the extra savings incurred by using a lower AKI/RON fuel, is up to the individual.
i totally agree, well said
Old Jan 7, 2006 | 11:44 PM
  #57
nismos14's Avatar
§è~® f®ÈÄk
Way to bring up an old dead a$$ thread!!!
Old Jan 8, 2006 | 01:17 AM
  #58
5spd2000SE's Avatar
Premium Chevron only. I won't go anywhere else...that's why I have a Chevron card.
Old Jan 8, 2006 | 04:45 AM
  #59
tedo007's Avatar
faster than you think
sometimes i put 87 in my car. reason i own a gas station and sometime gas delivery guy comes he puts 93octane in 87octane tank. so whenever he does that i put 87.
Old Jan 8, 2006 | 08:25 AM
  #60
DrKlop's Avatar
wow, how often do they do that?
Old Jan 8, 2006 | 04:12 PM
  #61
Back from the dead
lol, makes you wonder how true the ratings are... unless you all test the octane before putting it in your cars, it could invalidate every argument this has caused.... and gas guy error might add to the problem.
Old Jan 9, 2006 | 05:01 AM
  #62
ratha77's Avatar
I use 195 my engine explodes in flames........it's awsome
Old Jan 9, 2006 | 07:16 AM
  #63
9Nails's Avatar
Originally Posted by Coldboot-SE
80-90% of the Gas you buy comes out of the same tank farm and is delievered to Mobil, Exxon, Texaco, Chevron, etc in the same trucks where additives are added at the station.
Other "off the wall" brands are bought as "odd-lot" and sold through brokers and may be refined by a number of Petro companies.
A Good rule of Thumb is if it don't ping at 89 Octane you gain nothing by going higher, For the higher Octane gases Don't burn HOTTER just LONGER, as the octane increases they retard the burn as not to have predetonation, this becoomes a concern in higher compression engines.
Dave
I would have to agree. Except that, most computerized engines can better regulate the air::fuel mixture and reduce knock. (14.7 Lbs air to 1 Lbs fuel is the optimal mixture.) Carbureted engines were unable to adapt so well, and would knock with a lower octane rating. So, that logic still applies, but mostly to carbureted motors.
Most people think that Octane is a performance rating, or some sign to how volatile the fuel will be. Like a 87 stick of dynamite is good, so a 95 stick would be better right? It works that way for grains of gun powder, but unfortunately, it doesn't work that way for fuel. Octane ratings are used to match the compression of your engine to a fuel that will burn the most completely. A higher octane fuel will not burn completely in a low compression engine. You actually lose performance. And, not only does higher octane fuel have higher resistance to detonation, it can clog up your catalytic converter with unburned hydrocarbons. Which makes your car smell like it farted all the way home.
Old Jan 9, 2006 | 12:24 PM
  #64
max ride 41's Avatar
ok, i have a 95 with 142,000 miles on it. the dealer even say's it was'nt really made to run on anything but 87 > so every once in awhile i put 93 octane in there just to kick it up a notch!!! bam!!! it really does'nt matter that much unless you upgrade your max to high performance parts. i.e. engine, trans, suspension, etc., and are you people rich??? who can afford 93 octane anyway?? i make pretty decent $$$$$$ and i can't afford 2.89 a gallon!!!
Old Jan 9, 2006 | 01:41 PM
  #65
tavarish's Avatar
fwd gone rwd cr00
who's talking about low compression engines?
Resistance to detonation is a GOOD thing.
Old Jan 9, 2006 | 02:22 PM
  #66
STARR's Avatar
I run Mobil 93 all the time, and the regular verse premium debate is not so much about HP but more about MPG, my X had an M3 and we put regular in it, really performed the same but drank gas like an elephant, compare the cost of premium to 2-3 times that with regular and the savings is with premium but people see the 20cent savings and think before they even realize what they are actually doing
I've ran regular in the Maxima and with regular my MPG drops substantially, I do an entire week on a tank, regular I needed to fill up 2 days later.
It's about the MPG
Old Jan 9, 2006 | 02:49 PM
  #67
Dubbya's Avatar
VK56 Inside
93 only in my car. I figured after the swap why penny pinch?
Old Jan 9, 2006 | 03:43 PM
  #68
PHAT6's Avatar
I always try and use BP Ultimate 93 Octane but if that's not about I'll use regular 91 Octane - usually BP or Mobil.
In New Zealand the ratings are a bit bit different:
97 Octane = US 93
95 Octane = US 91
91 Octane = US 87
Stuff using 87 - can you say "BYE BYE KNOCK SENSORS?"
Old Jan 9, 2006 | 04:23 PM
  #69
4MySwee's Avatar
It's about the MPG
Starr, I too, have noticed a sustantial drop in mpg when I run with the mac-n-cheese fuel. The Max also tends to moan when I tromp on it. It lags....
However, when it gets Steak and potatoes, my mpg is 29.1 hwy and 24.3 city. And boy is it responsive..... Premium all the way, that is the kind of performance I want, therefore that is all I will pay for...
Old Jan 9, 2006 | 05:25 PM
  #70
sorry folks, i'm not seeing a substancial difference in performance or mpg when i use 93 as opposed to the "" mac and cheese fuel " as you put it. i fill it up on monday and have a week before i fill it up again, 87 or 93, does'nt matter. and no , it does'nt perform that much better, but once in awhile i'll treat it to a tank of 93 because it's good for the engine. it is only a car, right????
Old Jan 10, 2006 | 12:02 PM
  #71
PHAT6's Avatar
It is only a car, right????
Do you take the bus to work mate?
I've gotten a noticeable 40km (c. 25 miles) more in the city on high octane 93 unleaded and nearly double that when out on the open road.
Roughly 480km (c. 300miles) to the tank in the city and 680km (425 miles) out on the open road - though that's to when the orange petrol light comes on, not to when I'm conked out from no gas. My tank is the standard 65 or 68-Litre one. Considering I've got I/H/Full E it's pretty good consumption.
I started using high octane last November and have been taking notes on how much further I can go. But with 93 costing $1.55 NZD / Litre (about $4.10 USD / Gallon) it's still pricey. But passed emissions with flying colours! YAY!
Old Jan 10, 2006 | 03:24 PM
  #72
STARR's Avatar
mac and cheese
Old Jan 11, 2006 | 05:09 AM
  #73
i do want to say that i filled it up with 93 octane on monday and she's hummin like a kitty cat munchin down on cat nip. last night i was cruisin down 76 comin home from work and i was astounded at how much faster my coasting speed was. ( usaully is around 70 and was 80 to 85 ) and i was blastin so fast i had a hard time braking at times. i also flushed the transmission and put new fluid and conditioners in at the dealer yesterday and i think that made a world of difference.damn, i stand corrected!!!
Old Jan 11, 2006 | 05:38 AM
  #74
jaguax's Avatar
lol, that's all in your head dude, there's no way that a slightly higher octane fuel increased your speed.
I've tried premium a few times before and I always went right back to standard Mac and Cheese. I felt absolutely NO difference in performance and the price difference is not worth the microscopic gain in performance(if there even is any)... And like mentioned earlier, how do you TRUELY know that you are getting high octane fuel without testing it in labs and whatnot? There are a lot of scams going on out there, especially when it comes to money. For all you know that $3 a gallon gas you are buying is the same thing as Kraft Easy Mac.
Old Jan 11, 2006 | 07:29 AM
  #75
ummm. i pay 2.45 a gallon for 93 and you might be right, but i noticed an increase in power with it, regardless if it's untested or not. and my max has alot of new parts as of late, so maybe all combined with the 93 it finally runs like it should.
Old Jan 11, 2006 | 09:38 AM
  #76
maximase86's Avatar
I love lamp.
Conoco/76 92 or Costco 92.
And thinking higher octane fuel makes you cruise faster.....dude what kinda of stupid crap is that? Makes the car perform better...but there isn't that noticeable different.
Old Jan 11, 2006 | 12:38 PM
  #77
meccanoble's Avatar
Sports Button FTW
BP 93 Octane!!!!
Old Jan 11, 2006 | 04:49 PM
  #78
Maxima_99GXE's Avatar
Shell V-Power (93)
Old Jan 12, 2006 | 11:40 AM
  #79
keykeee's Avatar
i use to put amoco ultimate. now i just use regular
Old Jan 12, 2006 | 01:53 PM
  #80
to all you know it alls, it does step up the perfomance when you put 93 in, and to the dude that said shift allready, i have an automatic, i hate sticks. my max is stock, and i'm keepin it that way........later
