View Poll Results: What grade of gasoline do you put in your Maxima?
87 Octane
80
11.56%
89 Octane
87
12.57%
92 Octane
213
30.78%
over 92 Octane
303
43.79%
diesel: Are car takes gasoline?
1.30%
Voters: 692. You may not vote on this poll
What brand and grade of gas do you put in your Maxima?
Old Jan 27, 2007 | 01:41 PM
  #321
kenshi's Avatar
Originally Posted by Silver Dingo
Interesting poll. Down here they reccomend 95 octane or better for the 3.5 engine.
I believe the rating system is different in U.S. than in many other countries and that translates into higher numbers outside the U.S.
Old Jan 27, 2007 | 03:06 PM
  #322
Silver Dingo's Avatar
you may be on the money there Kenshi, but...you may not. After all you do drive on the wrong side of the road.
btw. Have any of you guys used the ethanol blend in your max. They are starting to promote it heavily down here but the results I got in my nissan truck were less than satisfactory. What are your experiences if any. Cheers.
Old Jan 27, 2007 | 03:30 PM
  #323
kenshi's Avatar
Perhaps, but I believe you Ozzies use a rating systme called RON (Research Octane Number) and the U.S. uses AKI (Anti Knock Index) where 87 AKI would be 92 RON.
Old Feb 1, 2007 | 02:04 PM
  #324
MrWangX's Avatar
93 Octane Only!!!!!!!
Old Feb 1, 2007 | 03:39 PM
  #325
Frank Fontaine's Avatar
Originally Posted by kenshi
You're correct if you put high-octane fuel in a low-compression cylinder where the fuel might not completely be consumed, but the energy output of a given amount of fuel is the same regardless of the temperature it ignites at and AKI index indicates what that temperature is.
I recommend reading this FAQ at http://chemistry.about.com/gi/dynami.../gasoline.html and read section 6.13.
The only difference in each company's detergents is their formulation. Please refer to the paragraph in this link :http://chemistry.about.com/library/w...abyb100401.htm that states:
Regular Unleaded Gasoline
The recommended gasoline for most cars is regular 87 octane. One common misconception is that higher octane gasoline contains more cleaning additives than lower octane gas. All octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against engine deposit build-up. In fact, using a gasoline with too high of an octane rating may cause damage to the emissions system.
I agree with you.
There are so many on this forum who actually think that their mpg's go up with super. The reality is they feel somehow that their cars are more important or valid if they use a more expensive gasoline. It would probably take a G35 with true duals for them to truly experience what they think they're experiencing with super in the Maxima.
I agree that up to 91 octane the Maxima has minimal gains. But as I said, I burned a lot of 93 out the tailpipe over the years, and now use stricty 87. No detriment, and my ego's not bruised in any way pumping 87.
Old Feb 1, 2007 | 03:49 PM
  #326
beakersloco's Avatar
Premium is all I use.
Old Feb 2, 2007 | 07:32 AM
  #327
clayman88's Avatar
I use 91 in my I30. I can't say that I tell a big difference between premium & regular, but thats what is recommended so I use it. I doubt there would be any noticeable gains using higher than 91.
Old Feb 2, 2007 | 08:00 AM
  #328
platinum03SE
hey i dont know about any of you on here my my maxima runs like **** on shell gas now. i used to put the vpower in my talon and it was great!!! put it in my maxima, ****!!!!
I stick with sunoco ultra 93 and mobile 93. i also used the valero gas a few time and noticed some more 'pep' in my cars performence.
BUT....anyone from the new england area, irving gas....93, lets just say go check it out for urself.
Old Feb 4, 2007 | 08:19 AM
  #329
chris288's Avatar
whatever 87 is cheapest,
Old Feb 4, 2007 | 06:22 PM
  #330
abustiffy's Avatar
Im a big person for running enough octane. However My 95 runs just as well on 89 as it does on 92. I dont have any knock data to back this up 100%. I do notice the car is a but more sluggish at wot on 87, so I put a stop to that after trying it a few times. If I were to ever do any serious mods Im sure Id step up, especially if knock was present. As of now the car is my comfy daily driver.
Old Feb 4, 2007 | 07:13 PM
  #331
kbjy11's Avatar
any dynos comparing running regular vs premium?
Old Feb 5, 2007 | 09:37 AM
  #332
kenshi's Avatar
Originally Posted by Frank Fontaine
:I agree that up to 91 octane the Maxima has minimal gains. But as I said, I burned a lot of 93 out the tailpipe over the years, and now use stricty 87. No detriment, and my ego's not bruised in any way pumping 87.
Well, my owner's manual recommends 91 and I don't really want to use anything less especially in very hot weather. In the wintertime I'm not as concerned. However, in the summertime, with different gasoline formulation and not wanting to have pre-detonation (knock), which is the worst abuse you can put on a piston, I want fuel with at least 91 octane.
The gas companies are pretty clever about what they sell though. You have to but a higher octane gas in your car than you really need. One way around it is to mix grades when fueling, but that means 2 transactions for an empty tank or fueling when half-empty and remembering what grade you last put in the car.
Old Feb 5, 2007 | 12:58 PM
  #333
kenshi's Avatar
http://forums.maxima.org/showthread....377#post740377
Old Feb 11, 2007 | 05:23 PM
  #334
RidinDirty's Avatar
Good ol Chevron with techron 92 oc
Old Feb 16, 2007 | 07:22 PM
  #335
maxforlife's Avatar
Cheapest one, cuz I don't giva F***
(and because I' poor)
Old Feb 16, 2007 | 10:32 PM
  #336
swatspyder's Avatar
Gotcha!
Im a sucker for premium although my max does seem to run better on it than regular.
Old Feb 17, 2007 | 02:17 PM
  #337
MrTrace's Avatar
Nothing like Shell's V-power (93) for me. I've used Exxon/Mobil's, Lukoil, Sunoco and Amoco's premium and none have given me the performance like Shell.
Old Feb 17, 2007 | 03:45 PM
  #338
doc2278's Avatar
Doctor D I presume???
93 octane,... sunoco style,...pay only 2.23 here in NJ.
she purrs with the 93, perky.
Old Feb 18, 2007 | 01:21 PM
  #339
adio's Avatar
occasionall, i use 89
Old Feb 18, 2007 | 05:04 PM
  #340
kenshi's Avatar
As probably mentioned earlier, BMW, General Motors, Honda, and Toyota developed standards for their approval of detergent gasolines. The current brands that meet the standards are:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
The Somerset Refinery, Inc.
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
This link describes the criteria that all grades of their gasoline must meet.
Old Feb 19, 2007 | 10:30 AM
  #341
ZaxWhite97Max's Avatar
I run 91 octane. Works fine. If I put something other cheaper grade in it. It always messes with my fuel sensor. Had to replace-
Old Feb 19, 2007 | 11:30 AM
  #342
d00df00d's Avatar
Old enuf to pick his own gears
...What the hell is a fuel sensor?
Old Feb 20, 2007 | 06:24 AM
  #343
Jason_03_Max's Avatar
i always use 93 from whatever place has it cheapest. no problems here.
Old Feb 20, 2007 | 01:42 PM
  #344
rmd0311's Avatar
Mobil 93 ONLY ----
If no Mobil around, I use whatever the cheapest most recognizable brand is. Here in the New York that usually Amoco
Old Feb 21, 2007 | 10:51 AM
  #345
MerlotMax's Avatar
The ECU is maped to run 91 octane(research). Nissan does not run a duel map like the higher end cars, ie BMW, to run different octane ratings. There is no gain in running over 91 octane unless the ECU has been remapped. It's just like burning your cash. I run Chevron w/techron 91 oct.
Old Feb 21, 2007 | 10:54 AM
  #346
kenshi's Avatar
Originally Posted by rmd0311
Mobil 93 ONLY ----
Mobubble was the first detergent gasoline marketed before federal mandates.
I haven't seen an Amoco station in years. Didn't BP take them over? In any case all grades and brands have to pass the same tests.
Old Feb 21, 2007 | 01:15 PM
  #347
choppy718's Avatar
sunoco 93, wuddnt have it any other way
Old Feb 21, 2007 | 07:08 PM
  #348
d00df00d's Avatar
Yes, they do. It's just that the two maps are for 91 vs. 87 octane...
Old Feb 21, 2007 | 07:19 PM
  #349
Nealoc187's Avatar
SLOW
I run 87 whatever brand in my daily driver max and 93 whatever brand (usually BP or Shell) in my turbo max.
Old Feb 21, 2007 | 07:22 PM
  #350
d00df00d's Avatar
See? That's why your user text says "slow as molasses".
Old Feb 22, 2007 | 06:54 PM
  #351
kenshi's Avatar
I'd like to read up more on that. Do have a link or a reference I could check out?
Old Feb 23, 2007 | 07:00 PM
  #352
TJM339's Avatar
I use 91 but have used regular and see no difference in performance
Old Feb 23, 2007 | 08:23 PM
  #353
andrei3333's Avatar
i never seen 92 gas in canada, just 87, 89, 91, and 94
i get 91
Old Feb 27, 2007 | 08:15 PM
  #354
absoundlab
120 all the way
Old Feb 28, 2007 | 02:10 PM
  #355
d00df00d's Avatar
Just noticed this response. One explanation is in this post: http://forums.maxima.org/showpost.ph...6&postcount=19
I know I've read more on this but I can't remember where. If I don't respond again, badger me by PM.
Old Feb 28, 2007 | 04:40 PM
  #356
03MAXTNR's Avatar
I mostly put 93 but when the prices spike, i tend to run 87 but only 1 or 2 fillups at most per month
Old Feb 28, 2007 | 06:46 PM
  #357
707SE's Avatar
I just filled up my wifes Ford Escort with Shell 93 VPower. I know it's an Escort but I'm interested to see how it performs.
I've filled the Max up with Chevron 93 the past year. I've wondered how the Shell 93 would do in the max...
Old Mar 1, 2007 | 04:33 AM
  #358
d00df00d's Avatar
It doesn't.
Old Mar 1, 2007 | 06:08 AM
  #359
HoMiE_TeLeFrAg's Avatar
We've got a station here that sells 94, 95, 100, and 110 (110 being leaded though...>.>) I usually just put 95 in it and drive on....^_^ -Ben
Old Mar 3, 2007 | 12:00 PM
  #360
dblock75's Avatar
91-Citgo...
