Header install day 1..
Whats up guys.. I just got off the phone with my mechanic and he said he got the front header off and on pretty easaly. I asked him how it fit? He said fitment was pretty good but he did have to trim a little off of one of the studs? He said he has the back header almost off and that it is going very smoothly so far. As of 20 minutes ago he has spent 4 hours on the job so far and expects about 2-3 more. I should be picking the car up tomarrow afternoon so I will let you guys now how the power feels and I will fill you in on the install details!
Heres a question for you fellas.. I asked a few times before but I never got a real clear answer. Ok, how long should I wait until I get the car dynoed after the headers are put on? Miles/day, estimate? I ask because people seem to think that it takes the ecu a little time to get adjusted. Also, should I definatly reset the ecu right after I get them out on?
You should just be able to reset the ECU, let the car idle 5-10 minutes. Turn it off and turn it back on and drive around for maybe half an hour. That should give it plenty of time to relearn it's program. Can't wait to hear if theres a power difference.
reset the ECU after and go dyno
http://vbxmaxima.8m.com/ecu.html <-- if you don't have it.. and yes that was from memory
. It looks like the car will get dynoed Thursday or Friday, maybe even tomarrow? Can you say 190-195 FWHP..?
Originally posted by emax95
Thanks for the info sprint.. I got that whole clearing the ecu thing down
http://forums.maxima.org/showthread.php?threadid=45274
It's Ok to admit it, Sprint. Really.
Originally posted by bill99gxe
No it wasn't. It was from here:
Originally posted by NickStam
Just make sure that you don't shift 5 - 2 on the way to the dyno.
, I was just thinking about how much that sucked ! I got that whole shifting thing down now
. My I30 is weird.. You can slide it into 1st gear at 110MPH if you want, with no problem, my max won't let me go into first unless I am under 20MPH ? Stange..
Originally posted by deezo
I remember that day to clear.
. Do I still owe you the ride back or what? LOLWe should set another meet up there soon!
Originally posted by BlkStnValyMaxima
You did get a Dyno before the install right?
bill .. seriously .. this is a serious post .. stop trying to build your post count.. go to the 5th Gen Forum
anyhow, thatnks for the update emax.... looking forward to the results
Originally posted by UMD_MaxSE
you possibly could..... you would have to move the two rear O2 sensors behind the main cat and remove the front manifold that has the precat built in. The headers should bolt up to the engine then...
Originally posted by max'n out
I can't wait to see these results... You said they were 600 plus shipping right? About how much is shiping? And what is the total hours install now that it's back?
VQ'ed
69
Aug 27, 2020 12:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
no time at all
