Those with SC and failed pullies
Old Aug 7, 2001 | 10:50 PM
CandiMan's Avatar
Say Candyman 5 times
I was wondering if the Stillen plastic pulley failed due to the plastic coming apart or the inner bearing freezing or any other reasons. Stillen pulley suppose to be made out of high temp plastic, correct? I realize a couple guys have upgraded to custom made aluminum/metal pullies did you use the same bearing or a upgraded bearing? Does either one of the pullies (idler or tensioner) fail more often than the other?
PS: Jane/Kev I couldn't resist, I had to ask
Old Aug 7, 2001 | 11:09 PM
Chebosto's Avatar
RIceD OuT moDErAtor
its the idle adjustment pulley (aka the one with RAILS)
the sucks spins so fast, the lube that stillen uses for the bearing over heats, and seperates, causing the pulley to slip off, and ruining your day.
stillen SUPPOSEDLY fixed this with new higher-temp grease.. but i dunno..
waiting for phil to finish the aluminum pulleys...
--C
Old Aug 7, 2001 | 11:42 PM
Cumalot's Avatar
--C
I'll be waiting for that. Then I'll put that in with my supercharger. I'm in no hurry, so it's a waiting game.
Old Aug 7, 2001 | 11:58 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
The tensioner/belt adjuster pulley is the one with rails while the idler pulley is the one without.
http://www.geocities.com/y2kevse/ima...ructions/7.jpg
http://www.geocities.com/y2kevse/ima...ructions/1.jpg
(copy and paste to see instructions).
Old Aug 8, 2001 | 12:02 AM
Y2KevSE's Avatar
Question... do you guys think the tensioner pulley will work for the idler pulley and vise versa? Pulleys with rails will keep the belt from slipping off, right? Why not use the one with rails for the idler pulley also? Hmmmmm.......
No problem Mike.
Old Aug 8, 2001 | 04:50 AM
Screaminfast's Avatar
Yep, I'm waitin for those also, but I decided to start putting my S/C in anyways....heh
Old Aug 8, 2001 | 08:10 AM
Cumalot's Avatar
Re: .
No problem Mike.
Interesting idea Kev. Hm...it should work, shouldn't it? Why don't you try it first and let us know.
Old Aug 8, 2001 | 09:20 AM
Y2KevSE's Avatar
Re: Re: .
I will, but I'm not going to let you know the result.
Old Aug 8, 2001 | 01:06 PM
Cumalot's Avatar
Re: Re: Re: .
Oh? I thought we are "gee gay yen"? So, you should let me know.
Old Aug 8, 2001 | 02:12 PM
Chebosto's Avatar
RIceD OuT moDErAtor
its the one with RAILS that fails...
cuz its trying to keep the belt inline, is causing the side to side motion.. more friction. boiling lube. then poof.
toast.
Old Aug 8, 2001 | 03:11 PM
BottleFedMax's Avatar
Hey Kev or anyone with a S/C. Why is it that there are two different types of intake piping on the S/C? I see that in Kev's sig pic that he has the black one yet I've seen pix of a polished one. Is it that only the ones that come with the BOV option is polished?
Old Aug 8, 2001 | 03:20 PM
Y2KevSE's Avatar
I've seen one person with a polished intake piping. The picture you see in Stillen's catalogue looks polished, but it's the angle the shot was taken.
4th gen piping is different than 5th gen piping.
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
JoshG
51
Sep 21, 2015 10:41 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
sdotcarter
Sep 2, 2015 09:53 PM
