Are there any advantages from running sparks plugs that are one step cooler than
Old Aug 9, 2001 | 07:43 AM
Blade_99SE's Avatar
stock? My car is just NA, no SC or NOS. I'm going to have my plugs changed today or tomorrow.
Blade
Old Aug 9, 2001 | 07:50 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Blade
Blade,
Read this post:
http://forums.maxima.org/showthread....threadid=45742
Look under the "Spark Plug" post. There is a link that helps explain the heat range differences.
Old Aug 9, 2001 | 07:53 AM
mzmtg's Avatar
Minister of Silly Walks
Heh heh...
Ask MedicSonic, he has dyno numbers and 1/4 mile times that will let you know just how much performance you can expect.
Old Aug 9, 2001 | 08:16 AM
Sonic's Avatar
I wouldn't do it unless your car is REALLY driven hard or for very long distances. I noticed a rather large decrease in performance when I put the colder plugs in (the car was noticably less 'enthusiastic' to go), and yes, I did make sure that they had the right gap and that they were installed correctly. When I changed back to the 'regular' heat range, the performance came right back. This was with absolutely no other changes in the car between the differences, so I HAVE to blame the plugs. Some dealerships supply both the regular ones and the cold ones and will install the colder ones if you don't pay attention (cough***Premium Nissan of New Rochelle, NY***cough), so make sure that they are the right ones.
Old Aug 9, 2001 | 02:23 PM
Kevlo911's Avatar
Kevlo for President
is there a way i can tell if i have colder runs spark plugs because i have had my service and i lost performance. my max is slow
Old Aug 9, 2001 | 07:43 PM
got rice?'s Avatar
Pull out the spark plugs and look at the part # printed on it.
Old Aug 9, 2001 | 08:03 PM
Sprint's Avatar
my parts buddy told me today at the dealership that the NGK's 5 range and the 6 range are the same exact plug.. no diffrence.. he even showed me the refference number on the plug.. they were both the same.. so now i am confused
Old Aug 10, 2001 | 10:14 AM
Sonic's Avatar
Then why would they have different numbers? Check out www.ngk.com, they list the PFR5G-11 as the OEM plug, the PFR6G-11 is a cloder plug. For more info on plugs and heat ranges, go to http://www.ngksparkplugs.com/techinf...s/overview.asp
Old Aug 10, 2001 | 11:11 AM
Mishmosh's Avatar
That's interesting. A few months ago when I got my spark plugs from Courtesy Nissan, they had the "6" listed as the OEM replacement and that's the one I got. I don't notice any performance loss or startup problems, unlike the Bosch Platinums I had in there for 4-5 months which sometimes took a few cranks.
Old Aug 10, 2001 | 11:31 AM
deezo's Avatar
Yeah, Medic lost bigtime torque with colder plugs.
Old Aug 10, 2001 | 06:09 PM
Mishmosh's Avatar
All this talk made me go out and sample one of my plugs. From what I gather from the NGK website, too cold a plug may result in an oily residue or even fouling. In my case, the PFR6G-11 plug looked perfect, not oily at all. Don't know if the appearance correlates to performance but at least it probably indicates normal operation. Interestingly, before I even knew what to look for in spark plug appearance, I remember the Bosch plugs that I took out were definitely oily--though not fouled.
Old Aug 10, 2001 | 08:26 PM
deezo's Avatar
Take a look at this site, {url]http://hammer.prohosting.com/~98fxdwg/plugs.htm[/url]
You'll see what you don't want your plugs to look like.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
cruce91
Sep 20, 2015 10:23 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
