help - 5 spd transmission noise
Old Aug 13, 2001 | 04:16 AM
psyclotran's Avatar
I have a 1994 5 spd SE maxima. I have a transmission noise I like to get some assistance on.
When the clutch is engaged, there is a mechanical rotating noise. The noise decreases with increasing gears (ie. louder in 1st then in 5th). When the clutch is fully depressed, the rotating noise goes away. I have no problem shifting 1st to 5th. The noise is less in 4th and 5 th gear. I am certain it is a mechanical noise but what bothers me is how can it happen instantly?
Everything was fine until I let the car sit in the driveway for two weeks while waiting for some other parts to come in. Then one morning, I drove the car and this noise came about.
Can bearings failed instantly? What went wrong? Tnanks.
Old Aug 13, 2001 | 10:51 PM
MR_Maxi's Avatar
I've just had the same prob in my 4th gen, apparently the bearings are known to fuse to sleeves when over heated, which will give you a rattly bearing noise.
Old Aug 14, 2001 | 05:18 AM
psyclotran's Avatar
strange
Which bearings on yours was messed up?
I do not drive mine hard at all, how did the trans overheat?
KabirUTA13
19
Oct 17, 2015 02:15 AM
homewrecker
Sep 24, 2015 07:01 PM
lrb6805
Sep 17, 2015 04:49 PM
220k+ A32
Sep 11, 2015 02:18 AM
