whos installed a LEVOC auto knob?? -->
Old Aug 27, 2000 | 03:01 PM
WiC's Avatar
WiC
Any info or tips before i try installing this thing
Old Aug 27, 2000 | 09:36 PM
mingo's Avatar
ask y2kev he has one installed n/m
nm
Old Aug 28, 2000 | 08:29 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Check your email WiC...
Old Aug 28, 2000 | 07:09 PM
Shadow's Avatar
I did this a long time ago. Only thing you might want to do is to use locktite on the bolts since they tend to come loose. And make sure you cut the O/D wires long enough so that it's not hard to splice.
Old Aug 28, 2000 | 08:53 PM
hodgeee
I recommend
Cut down on the actuall shifter rod. I cut the inner rod and outer rod by about 3/4 of an inch, and the shifter sits lower to the gate, and doesn't look as tall. I thought it looked a little goofy with how tall it was. If you got a dremel it is easy to cut the bar. Just don't cut it too short.
It looks much sweeter with the lower stance, and don't forget to file very lightly the plastic boot to which the wire covering goes into, it makes it shift a little smoother where it used to kind of stick to the plastic gate.
Also if you have an angle head drill bit, I recommend that you drill a new hole on the metal rod to accomadate the large screws that come with the unit. They hold much better than the three little Allen head bits.
Old Aug 29, 2000 | 10:23 AM
Chebosto's Avatar
RIceD OuT moDErAtor
there are instructions on my site...
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxboy23
Sep 9, 2015 10:37 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
