stripped lug nut.....how to get it off???
Old Sep 8, 2001 | 07:17 PM
pawn's Avatar
ok, i was going to take off my wheels....and i noticed one of the lugs on the wheel of back passenger side was stripped......any ideas on how to get it off??????
Old Sep 8, 2001 | 10:20 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
take it somewhere to get it done, it will take you hours and you will demolish your rims.
Old Sep 8, 2001 | 10:25 PM
pawn's Avatar
what do they do to keep from demolishing the wheels?
Old Sep 8, 2001 | 10:33 PM
emax02's Avatar
They will probably use a hot chisle.
Old Sep 8, 2001 | 10:36 PM
and they are professionals, you've never gone this before.
Old Sep 9, 2001 | 12:14 AM
Nismo's Avatar
I known someone who had to use a cutting wheel attached to an air compressor and just cut around the bolt. destroyed the rims.
Old Sep 9, 2001 | 12:17 AM
pawn's Avatar
but you don't have to destroy the rims to get it off do you?
Old Sep 9, 2001 | 12:30 AM
Nealoc187's Avatar
SLOW
Ummm... I've got a better idea. Happened to me, 3 times (don't ask). If the lugnut is stuck and won't turn, heres what you do. Get a breaker bar and stick pipe (I actually used an aluminum hockey stick shaft) on the end of it, and start turning. What will happen is you will eventually twist the stud enough so that you break the stud, you give it enough torque and it WILL give, and then you will be able to get your wheel off. Then you just have to replace the stud, which is a very simple process. Viola... you've got your stripped lugnut/wheel stud off, and your wheels are still in perfect shape. A new stud and lugnut will run you about $2 a piece. Much cheaper than the labor they will charge you and definately cheaper than replacing a wheel if they happen to ruin it.
Old Sep 9, 2001 | 05:20 AM
good idea, but from that he said it sounds like the nut is rounded off.
Old Sep 9, 2001 | 09:08 AM
shane's Avatar
I have seen a blow torch uced on lug nuts before.How would you get tuner lugs off if messed up on the car
Old Sep 9, 2001 | 04:47 PM
pawn's Avatar
so does anyone know how much this will cost me??????
Old Sep 10, 2001 | 07:18 PM
from the back side of the lug, break it from there.
Old Sep 10, 2001 | 10:55 PM
nizmolee's Avatar
this has happened to me several times.. must be b.c of so many rims changes. but to get to the question, nealoc is a good suggestions, i just used my stock lug opener and jumped on till the stud gived, cuz i tried using a chisel, and hammer, but it messed up the rim hole. well good luck. its pretty expensive at a tire center, they charge 20 to 45 bucks.
Old Sep 11, 2001 | 05:02 AM
Enduro's Avatar
My friend's audi had a stripped lug nut and the mechanic said all he did to remove was to use a smaller size socket size. He must've used a hammer to force the smaller socket onto the lug nut and got enough grip from that.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
rbarnes
Dec 31, 2015 06:29 PM
RealityCheck
Oct 2, 2015 06:34 PM
dcam0326
Sep 26, 2015 05:20 AM
maxima297
Sep 24, 2015 08:57 PM
