UDP Install and Impressions
Old Sep 20, 2001 | 05:59 AM
ejj's Avatar
ejj
Well, I finially decided to install my UR UDP Monday night. Its been sitting in my room for months, waiting for belts and the oil seal. Once I got everything I got into my accident, so needless to say, this was put a hold a while.
Install
Install should have been pretty simple.
Removing the stock belts was simple. Getting the bolt off of the stock UDP was far from easy. My roommate was in the car holding the brake, and put the car in 5th gear. It took a good bit of work, but we finially got it off.
The oil seal was easy to get out, just pry it out with a flat head screwdriver. Coat the new one with oil and put it in. A rubber mallet made this a little easier, as its a tight fit.
Here's where it got interesting. I installed the new UDP with no problem. Went to install the PS belt (the smaller of the two) and could not get it on no matter what I tried. Now, UR has a alternate belt size that you can use, but I didn't get that one, I got the smaller one.
So, what I did was take the UDP off, put the belt on it and the PS pully, and then re-install the UDP. This made getting the PS belt on a whole lot easier!
Tensioned the PS belt and moved on the to main belt. This belt is a whole lot easier to get on. It will help to have a second person to hold up the tension pully, otherwise it will be pressing against the belt as you try to get on.
Here is where I ran into a problem. As I was under the car my roommate was lowering the tension pully by tighetening the tension nut. Well, all the sudden we both heard a snap. The tensioner bolt snapped in two! So, this was about 9:30pm, so we called it a night.
Next day I went to my local Nissan Dealers (3 of them) to try to get this bolt. No luck. The nut and bolt costed $13 and they had it overnighted and I got them the next morning (Wednesday).
Impressions
After installing the pully I went out for a spin. First thing I noticed is that there seems to be a lot less engine braking at low speeds.
The car seems to accelerate smoother and quicker throughout the powerband. It will be interesting to see what it does at the track. On the highway this morning I floored it in 5th gear and noriced a lot stronger pull. Other than that I haven't really pushed the car yet...for some reason my head tells me to let the pully and belts "break in", although I don't think this is necessary.
I am going to the track either Friday or next Wednesday, so I'll post my results.
Old Sep 20, 2001 | 06:04 AM
NickStam's Avatar
Re: UDP Install and Impressions
interesting
Old Sep 20, 2001 | 09:30 AM
ericdwong's Avatar
Question- which pulley(s) does the UDP replace? I'm assuming power steering, Air conditioner and alternator?
I wouldnt mind toning down the air conditioner and steering but I want my alternator running at full blast. Can I replace all the other pulleys except for the alternator?
Old Sep 20, 2001 | 09:37 AM
ejj's Avatar
ejj
You've got it backwards. The Power Steering, Alternator and AC pullies stay as they are. This pully replaces the Crank Shaft Pully that drives all the other ones.
If you look under your car, its the one right next to the oil filter.
Old Sep 20, 2001 | 05:57 PM
Dave B's Avatar
Not DAVEB the parts guy
What I noticed most was there was absolutely no lag between shifts (ie I was able to hit my shifts harder). OH!! And the fact that I ran 1.5mph faster with my UDP (95.5mph).
Dave
Old Sep 20, 2001 | 06:11 PM
ejj's Avatar
ejj
Dave
Yeah, I haven't really hammered it yet, but I can kinda see what you're saying.
1.5 mph huh? Not bad. I was hoping to see those kind of gains between the Cat-Back and UDP combined!
Old Sep 20, 2001 | 07:05 PM
My 4DSC
Dave
that 1.5mph is not the result of your UDP...
note your ET was worse along with your 60'...
the reason: wheelspin
wheelspin results in a higher mph...
the reason: because you're shifting gears earlier...
(see below for an explanation)
WARNING:
the following explanation may seem like rambling but if you can somehow understand it, it will make sense:
in other words, with wheelspin you hit the shiftpoint quicker which means you shift gears earlier in your trip down the 1320', which means you'll finish your run at a higher rpm than w/o wheelspin, and higher rpm = high mph...
get it? got it? good.
Old Sep 20, 2001 | 09:53 PM
ohboiya's Avatar
Do we really need a new oil seal?
Old Sep 20, 2001 | 10:11 PM
Dave B's Avatar
WARNING:
Oh really? I guess you don't know me too well then. I'm a "numbers" guy and I look at my timeslips very closely. I want you to chew on these slips and then get you explaination:
Best run to date without UDP:
14.73@93.93mph 2.28 60'
Best mph to date with UDP (not my best et though):
14.91@95.5 with 2.31 60'
Best et with UDP:
14.81@95.08 with 2.30 60'
Sample of runs without UDP and 2.3X+(spinning) 60 foots:
15.21@92.35 with 2.36
15.31@92.11 with 2.55
15.11@91.98 with 2.37
15.03@92.05 with 2.38
15.21@93.15 with 2.42
14.93@92.47 with 2.31
As you can see, the mph to 60' correlation you speak of is all over the place. It is clear to me that last Friday night showed me the UDP did do something. I went from running consistent 93mph traps without the pulley, to running consistent 95mph+ traps with the pulley. Something is giving my the power and the only thing that changed was the pulley. The weather that evening wasn't even remotely close to the weather I ran my best et in plus I was less than .1 off my best et on Friday night (14.81 vs a 14.73). Heck, my 60 foots were only .02 worse (2.30 vs 2.28).
Not trying to flame you.
Dave
Old Sep 20, 2001 | 10:12 PM
khrfadz's Avatar
i remember reading that if u have a stereo system in ur car then u cant run the udp and the system at the same time. why is that so?
Old Sep 21, 2001 | 02:17 AM
BrianV's Avatar
Alternaotr doesn't make enough juice with larger pulley.
Old Sep 21, 2001 | 03:56 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Install
Impressions
so are we twins, i think i had all those problems happen to me, the too small PS belt, you could have walked it on though, i got mine to. then i snapped the bolt too. i ordered it from COZ, because it is special order, but that i did for now was has my grandfather push down on the pulley as hard as he could with a metal rod and then i tightened the axle bolt and it's been working for over a week, it does squeak below 2500rpms when the a/c is one but oh well. i ordered a new belt from him too so once it gets here i'll be ok.
Old Sep 21, 2001 | 04:46 AM
ejj's Avatar
ejj
I doubt it, but it can't hurt. The seal is like $6, and its a pain to get the pully off...so you should change it when you have the chance.
Old Sep 21, 2001 | 05:00 AM
UMD_MaxSE's Avatar
Got Bent?
i didn't replace mine.... but then again, my car was less than a year old when I installed it
Old Sep 21, 2001 | 05:32 AM
ejj's Avatar
ejj
You mean smaller pully?
Old Sep 21, 2001 | 07:51 AM
My 4DSC
Best et with UDP:
Dave
Wasnt trying to flame YOU either...
Just trying to inform people here about the relationship between 60' and 1320 MPH/ET...because many people don't get it and it's very important...especially with regards to racing/tuning FWD vehicles...
I'd be curious to see the list of ET/MPH *with* the UDP...
Also the 330', 660', and 1000' give you some good info too...
There's alot more to a run than just 60' and 1320'...
Especially when the correlation is all over the place (not consistent)...For example:
"15.03@92.05 with 2.38"
"15.21@92.35 with 2.36"
Like between these 2 runs, I'm wondering what happened inbetween the 60' and 1320' for you to run 2/10ths slower with a BETTER 60'....
I'm guessing you were trying different shift points...or missed a gear?
I wasn't there and haven't seen your full timeslips yet but by the info I was given I still don't see that 1.5mph being a result of the UDP...who knows?
When traction was a problem for me, I myself would see huge differences in MPH of +/- 5mph...
Back when I was supercharged, a 2.4 60' run would yield 105+mph at 14.0+ ET whereas a 2.2 would yield 102mph at a 13.8 ET.
Sorry if you took offense to my little class on traction...I wasnt preaching to you...I was trying to inform the community at large...I was just using your #'s as an example...
Old Sep 21, 2001 | 12:20 PM
Dave B's Avatar
I didn't take it as a flame, but the spinning 60 foot = high trap speeds just doesn't seem to apply much to FWD cars. My 60 foots are so close (within a .1) that I don't see how it could be responsible for a fairly dramatic 1mph+, consistently. Like you said, it is a hard thing to explain. Looking at all my timeslips and comparing my Friday night runs with 95mph trapspeeds to the April runs without the pulley look like this. Friday night I was getting 1/8th miles in the 9.60 range @74-75mph with the 2.30 60 foots. In April I was running lots of 14.7s,14.8s, and 14.9s with 1/8th miles in the 9.45 range @74 with 2.25-2.28 60 foots. By comparing the numbers for the 330', 1/8th, and 1000', it looks to me that I'm picking up mph in the topend. My shift points stayed the same:
1-2 6500
2-3 6300
3-4 6100
Dave
Old Sep 21, 2001 | 07:24 PM
ny96max's Avatar
question for any one with the UDP:
will this mod make any difference if im an automatic with a cattman Y pipe and apexi ws-catback and CAI??
opinions/reccomendations only please!!
Anthony
Old Sep 22, 2001 | 05:06 AM
Anthony
a little bit, i'm still deciding whether or not it was worth the 200bucks and all the headache of putting it in.
Old Sep 22, 2001 | 06:21 AM
MaDMaX024's Avatar
question about pulleys
could i have my stock pulleys lightened? i wouldnt mind having my AC and power steering toned down (like someone else said) but i need all the juice i can get from my altinator at all times (soon to be a 1500watt stereo will do that).
thanks.
Old Sep 22, 2001 | 06:38 AM
My 4DSC
Dave
When traction is a major issue (ie: HIGH power FWD car) that correlation is DEFINITELY quite obvious...it is also an issue when cars, such as yours and mine, have only minor traction problems but it's just not as pronounced...
Old Sep 22, 2001 | 09:43 AM
ohboiya's Avatar
Just got my pulley ... damn that thing is LIGHT!!!
Old Sep 22, 2001 | 11:37 AM
UMD_MaxSE's Avatar
Got Bent?
cool.... did you get the right belts? Coz refunded me like $20 for the ones I sent back....
Old Sep 22, 2001 | 12:42 PM
ohboiya's Avatar
really? he only offered me $18? ... LOL .. n e ways .. I didn't return .. he just sent the right one out ... haven't installed them yet ...
I'll let u guys know!
Old Sep 22, 2001 | 01:04 PM
UMD_MaxSE's Avatar
Got Bent?
actually, I checked my CC statement... it is $18.
Max8
Sep 22, 2015 02:53 PM
cruce91
Sep 20, 2015 10:23 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
jfl330
Sep 4, 2015 01:44 PM
