STOCK 4th gen hits 14s in the 1/4
Old Sep 22, 2001 | 04:54 PM
BriGuyMax's Avatar
Everybody has said that 5th gens are faster than 4th because they have hit 14s stock.
Today at Route 66 Raceway in Joliet, IL Nealoc187 ran a 14.94 in his 96 GXE 5-speed with only suspension mods. He doesn't even have an intake! I am very impressed to say the least. This was his FIRST time at the track with his max.
Has anyone else with a 4th gen ever hit 14s stock?????
Old Sep 22, 2001 | 06:19 PM
RussMaxManiac
Re: STOCK 4th gen hits 14s in the 1/4
No one ever has, but I still find that kinda hard to believe. Don't take it wrong, but he might have had a OSCAI or something. Stickier tires help, suspension as well.
So he had his advantages..but congrats here.
Old Sep 22, 2001 | 06:23 PM
NickStam's Avatar
Re: Re: STOCK 4th gen hits 14s in the 1/4
good job
Old Sep 22, 2001 | 06:27 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Geez watch out integra GSR.
Old Sep 22, 2001 | 06:41 PM
VQdriver's Avatar
i've never seen a 5th gen run 14's. they need more representation.
Old Sep 22, 2001 | 06:45 PM
RussMaxManiac
Re: Re: Re: STOCK 4th gen hits 14s in the 1/4
Then your blind...
I can't count how many have, too many to count.
One hit 14.3 with just a CAI and ypipe...
Old Sep 22, 2001 | 08:08 PM
Nealoc187's Avatar
SLOW
hehehe... disbelievers all of you. well not all of you... just russ. thats ok though, josh and steve from the org. both saw my car today, and trust me its stock. Brian will see it tomorrow, assuming its not raining. i'd like to have some engine mods, but i dont yet. I'll post timeslips in a new thread in just a second.... 14.94 wasnt my best run, it was actually my 2nd slowest... unless you count the 17.07 i ran, but that one was messed up
Old Sep 22, 2001 | 08:12 PM
AznWontonboy's Avatar
russ just said you werent stock.. i think he meant you have less squat from the coilovers and your sticky tires help the launch, giving you a better time...
Old Sep 22, 2001 | 08:21 PM
Nealoc187's Avatar
SLOW
he said i might have an OSCAI, i dont. hehe sticky tires... read the post i will post in a second and you will learn about the crap tires i was running on...
Old Sep 22, 2001 | 08:38 PM
RussMaxManiac
Any tires better than stock are better. Kumhos are very good tires from alot of people I have heard. Okay, still good run you are stock, suspension helps!
I was not disbelieving you...
Old Sep 22, 2001 | 08:54 PM
NickStam's Avatar
255/45/17's right? Or whatever large size they were
Old Sep 22, 2001 | 09:04 PM
Sonic's Avatar
I bet it was the upgraded brakes that help you.
Old Sep 23, 2001 | 12:47 AM
BriGuyMax's Avatar
Russ, so the suspension that I plan on getting should drop my et .2 seconds or MORE!?!?!!? Damn...I better get suspension
Old Sep 23, 2001 | 05:57 AM
Sonic's Avatar
In theory it should. The stock suspension allows for alot of front end lift off on sudden acceleration, throwing the weight of the car towards the back and causing a loss of front end traction. Stiffer springs should help that to a small degree.
Old Sep 23, 2001 | 10:47 AM
mitch33x's Avatar
Yeah...if you have Koni's set on soft..you will run a 16...if you set them to full firm then you will be running 13's for sure... ...suspension does help 1/4 mile time.....not .2 seconds...
Old Sep 23, 2001 | 11:42 AM
Synki's Avatar
Re: Re: Re: Re: STOCK 4th gen hits 14s in the 1/4
Then your blind...
Congrats on hitting the 14's stock. The closest i have seen anyone tot doing this was a guy with a 98SE w/ only a catback running a 14.8 & Aaron (Theblue) wiht a exhaust only.
Adam (MY4DSC) use to run consistent 14.9's in his stock 2k. He added a K&N cone & 18" rims and ran 14.8. hehe.
ANd the 14.3 run was done by Larry (madmax2k). He says he usually runs 14.5-14.4's most of the time.
Old Sep 23, 2001 | 02:02 PM
theblue's Avatar
a stock max can run 14.8s... it kind of sucks that I never had the chance to do that because I never raced before I got my exhaust. I don't think its possible for consistant 14.8s or even a 14.8 with the temperature above 70 but they can be done with practice.
Old Sep 23, 2001 | 03:44 PM
RussMaxManiac
Stiffer the shocks/springs the harder it will keep the front tires planted, meaning less wheel hop and more traction.
Old Sep 23, 2001 | 03:51 PM
BriGuyMax's Avatar
Russ....you didn't catch my sarcasm in that post...come on man...you seriously think that if he put stock spring and struts back in that he would be up to 15s???? NO WAY...the conditions weren't even very good yesterday..something like 85 -90% humidity and 75 degrees at 700ft MSL. I'll bet he could get 14.7s with better conditions and stickier tires.
Old Sep 23, 2001 | 03:54 PM
RussMaxManiac
Who knows. I just know that suspension helps lanches.
Old Sep 23, 2001 | 03:58 PM
Dave B's Avatar
Not DAVEB the parts guy
I doubt he'll be in the 14s consistently with the way he sits, especially if he were to run in warmer weather. It sounds to me like he's just a pretty good driver and the track was decently sticky. The suspension does help somewhat. Tires don't mean squat as long as they aren't bald. Low profile V and Z rated tires are more for lateral g's, not straight line. I've pulled 2.25 60 foots with bald RSAs. Taller tires are actually better for drag racing.
I'd bet when he adds a Y-pipe, intake, exhaust he'll be in the 14.5-14.7 range like the most of us.
Pretty much any car that is capable of 90-91mph in the 1/4 mile, is a capable of 14.8-14.9s with 2.1-2.2 60 foots.
Old Sep 23, 2001 | 04:04 PM
VQdriver's Avatar
i ran 14.9, 14.7, 14.6 respectively with just a cone filter. you can check the "post 1/4mi times" post. i doubt a cone filter is good for 2 tenths. you can give me the benefit of a doubt i would be under 15 seconds in the 1/4 if i was completely stock. the point that 4th gens can't run 14's stock is rediculous. it's almost the same thing as saying that all 5th gens run 15s stock. that's how i feel. i really believe that maximas were made to run 14's.
Old Sep 23, 2001 | 04:25 PM
BottleFedMax's Avatar
What i noticed about most of you guys that run 14's stock are GXE's. I believe that this is because the GXE's have less options on them therefore weigh less and gives them that advantage.My friend has a 99 SE Limited and it has practically no options on it ( no sunroof,no ABS,no leather/power seats,)His car weighed only 2800 lbs.
Old Sep 24, 2001 | 10:01 AM
Uncle Max's Avatar
I ran a 14.9
Also bone stock including suspension. Francise 96 saw me run it. I got three that day. Also GXE
Old Sep 24, 2001 | 10:09 AM
RussMaxManiac
Re: I ran a 14.9
Whats with the fake intercooler? lol
Old Sep 24, 2001 | 10:25 AM
Uncle Max's Avatar
Re: Re: I ran a 14.9
Dude that offended my pc so much it locked it up and I had to reboot.
Old Sep 24, 2001 | 10:28 AM
RussMaxManiac
Re: Re: Re: I ran a 14.9
LOL... I am just giving you a hard time.
Sprint's Avatar
GXE'S RULE!!!!!!!!!!!!!!!!!!
Old Sep 24, 2001 | 10:41 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Old Sep 24, 2001 | 11:47 AM
99NosMax's Avatar
my 4th gen ran a 14.67 with only cone intake & cat back exhaust
the 1/4 mile times was very consistant
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 6, 2015 11:36 AM
