True dual exhaust...
Old Sep 25, 2001 | 11:20 AM
Greg's2kGLE's Avatar
Has anyone done or heard of someone put a true dual exhaust system on the Maxima? It is just an idea, but can't you have a custom job for two separate pipes coming from each header and have them come together into one muffler? I say one muffler because I don't think dual exhaust pipes (one on each side) would look good on a Maxima.
Old Sep 25, 2001 | 12:19 PM
mtrai760's Avatar
'Trynna' is not a word
Dual exhuast looks good and it's been done...
Old Sep 25, 2001 | 12:32 PM
NickStam's Avatar
I don't think a true dual has been done. Just ones for show.
Old Sep 25, 2001 | 12:37 PM
mbcp_tdogg's Avatar
Could've sworn I've seen pics on the Org of someone with a true dual exhaust. Of course, it was awhile back...
Old Sep 25, 2001 | 12:48 PM
Sonic's Avatar
That's A LOT of work. I only know of split exhausts from the cat back.
Old Sep 25, 2001 | 12:53 PM
tomj's Avatar
I don't think there would be enough room underneath. Where would you put the extra piping and cat?
Old Sep 25, 2001 | 01:14 PM
gtr_rider's Avatar
192.168.1.1
1/3Here2/3Togo has a dual exhaust setup, also that black max with the big wing has dual exhaust cant remember is tag on here though.
Old Sep 25, 2001 | 01:19 PM
NickStam's Avatar
i think they split at the cat though...so it's not a true setup.
Old Sep 25, 2001 | 01:22 PM
MaximaRider's Avatar
yea
5litrekiller is the one with dual but i also think its not a true dual its only split at the backend
Jeff92se's Avatar
I'm needing a caw
A honest to god true dual exhaust system "could" be done but in order to even attempt to get the exhaust pipe equal length, you would have to have the pipes run "under" the unibody and not along the tunnel the provide for it. Thus you would lose alot of ground clearance. BMW have a true dual exhaust from the manifolds to the muffler
Old Sep 25, 2001 | 02:37 PM
Dave B's Avatar
Not DAVEB the parts guy
A true dual can be done fairly easily. Running two cats will be the hard part. Here's what you could do. Since we've only got a 3.0 DOHC motor, piping any bigger than 1.5" isn't really needed. Since the aftermarket Y-pipes run ~1.5" tubing off the manifolds, you could simply cut the joiint where the two pipes "y" into one another. You would then carry this piping in the stock location, but have the two pipes on top of one another. They would be tack welded to each other. Then follow the same pattern as others have done with the dual mufflers on either side OR even better, have Borla bullet mufflers on each pipe and have them exit in the stock location.
As for the cats, you'll need one for each pipe. If anything, buy a couple Honda cats which are bullet shaped. You could stager them for clearance. You would probably also want to have a H-pipe joining the two pipes somewhere aroudn the converters to equalize exhaust pressure on each bank.
Dave
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Sep 27, 2015 08:37 AM
