Maybe Daniel B.? umm.. Where is the fuse for the Antenna Motor?
Old Sep 27, 2001 | 09:27 AM
thebigsadler's Avatar
How do i disengage the antenna motor.. i looked on the fuse cover and under the hood and did not see a fuse for "antmtr" or anthing like that.. and i cant find a way to disconnect power to it in the trunk.
98 GLE... thanks
Old Sep 27, 2001 | 09:29 AM
Sprint's Avatar
disconnect it from the back of the radio
Old Sep 27, 2001 | 10:03 AM
then i have no antenna what so ever.. i just dont want it going up an down.
Old Sep 27, 2001 | 10:05 AM
Sprint's Avatar
there is a power antenna lead in the back of the radio.. not the antenna connector
Old Sep 27, 2001 | 10:13 AM
«§»Craig B«§»'s Avatar
there wont be a single fuse specifically dedicated to the antennea motor
as for 3rd gens, if you open up the trunk and remove part of the lining, you can get to the motor assembly and disconnect the harness going into it without disconnecting the actual part that you want for your radio; I assume it's probably very similar on 4th gens too
AaronL
Aug 8, 2020 10:31 AM
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
leatherneck
Sep 30, 2015 09:16 PM
