Big Brake Kit? Brembo?
Old Oct 2, 2001 | 09:59 PM
mrb23's Avatar
Hmm, I haven't heard brakes being mentioned on the forum much. I probably need new brake pads soon (about 48k on stock right now). But I'm curious as to what brake systems and stuff you guys have and how much it would be (price + installation). I've been hearing good things about Brembo and I do like the cross-drilled look. I have 18s on right now, so I think I could fit some bigger ones now. thanks
Old Oct 2, 2001 | 10:36 PM
Slickismax's Avatar
The only big brake kits available right now are from stillen. They are like $2400 for the two piece rotors and $1800 or so for the 1 piece rotors...i think. I know I'm pretty close on those numbers. There have been a few attempts at making other big brakes, I know there is a willwood conversion somewhere, and one of these years maximadriver.com will have their big brake kit available.
Old Oct 2, 2001 | 10:42 PM
Kevin Wong's Avatar
I'm about to do the Wilwood upgrade on Friday
I've had them for about 6 months, but they've been sitting in the box waiting to be put on.
Old Oct 3, 2001 | 11:02 AM
Regime's Avatar
The non-postwhoring Org member
Re: I'm about to do the Wilwood upgrade on Friday
Avalonracing.net has a 6 Piston Big Brake set, I believe stillen only has a four piston not sure on the pricing you can go check it out if you are interested. (the 6 piston set should theoreticly give you smoother firmer stopping power)
Old Oct 4, 2001 | 12:47 AM
Chunger's Avatar
My other car is a Hybrid
Some pics of the FASTBRAKES WILWOOD kit... click on the part in my sig below...
Old Oct 4, 2001 | 07:45 AM
1MAX2NV's Avatar
Brembo makes a 2 piece rotor and 4 pot piston for the Maxima. I actually seen it once on Carparts.com for $1800ish with their 25% off coupon. That was a killer deal, but I already have my Stillen big brake kit on. If you decided to go with Stillen, get the 2 piece rotor version. You will save aleast 10-15lbs.
Old Oct 4, 2001 | 10:46 AM
Kevin Wong's Avatar
Thanks Chunger
Pictures are worth a thousand words, especially when installing these suckers. I'm going to be doing the install with Orgedave so it'll be two people working, but of course we'll be doing his kit too. I think mine is going first, if we have any problems I have 2 other cars to drive. I just have a few quick questions:
1) We'll be installing stainless steel brakelines and I was wondering how much brake fluid is needed to bleed each car?
2) Do the brake pads just sit in the caliper with the bridge pin and bridge bolts separating them? I'd imagine the pads would rub against the rotors when the brake pedal is not applied.
3) Any negative effects from the kit? I've been so optimistic about the kit that I'm blinded from any cons other than never going back to 16" wheels.
thanks so much again.
Old Oct 4, 2001 | 11:06 AM
Chunger's Avatar
Re: Thanks Chunger
Depends how much brake fluid you 'leak' or keep from leaking... I would get a large bottle cuz you'll want to do a complete bleed anyways... I did.
The pads just 'load' from the top and are held in by the two bridge bolts and the retaining pin... All disc brake pads will 'rub' up against the rotor... that's normal... I had quite a bit of squeal for the first several hundred miles... It will go away.
Negatives? hmm... deeper/lighter pedal travel and effort; cool down noises (clicks, pops etc); there are some ocassional noises when you apply the brakes; the increased vigilance to 'maintain' these calipers (inspections) due to the lack of dust seals.. I haven't had any problems in this respect, even with a strong stream of water during the times when I wash my car. The pads do dust a lot, at least the Polymatrix D compound those of us in the first GB got.
Over all.. I'm very happy with these...
Old Oct 4, 2001 | 01:45 PM
j_bryan's Avatar
Re: Re: Thanks Chunger
Chunger,
in your opinion, what are the 3 best benefits for upgrading stock brakes to the wilwood kit??
thanks
Old Oct 4, 2001 | 03:10 PM
max'n out's Avatar
mmmmmmmm brembo yummy
do they clear the factory 17's
Old Oct 4, 2001 | 03:16 PM
ohboiya's Avatar
no
Old Oct 4, 2001 | 04:55 PM
Chunger's Avatar
Re: Re: Re: Thanks Chunger
Originally posted by j_bryan
Chunger,
thanks
1) stops in shorter distance...
2) stops in shorter distance...
3) stops in shorter distance...
Seriously... 1) As stated above 2) shaved off about 12lbs (IIRC) off each corner 3) looks bad a$$.
Old Oct 4, 2001 | 06:53 PM
max'n out's Avatar
Originally posted by ohboiya
no
I know the stillens don't but how do you know the brembo's don't
Old Oct 5, 2001 | 05:36 AM
j_bryan's Avatar
Re: Re: Re: Re: Thanks Chunger
thanks.. what is IIRC?
Old Oct 5, 2001 | 01:46 PM
Chunger's Avatar
If I Remember/Recall Correctly...
Old Oct 5, 2001 | 08:46 PM
Shadow's Avatar
Because the caliper is just as big. Let's just say that no aftermarket caliper will fit under the stock 17"s. Not the AP/Stillen, not the Brembo, not the 300ZX, not the Skyline ones. They are all 4 piston calipers and much too wide. It's not the height of the brake, it's the width. Look at a factory caliper, look at a Brembo, tell me that the Brembo will fit under there. I had to space out my 19"s 6mm just to clear my 300ZX brakes. Stock wheels have even less clearance.
Old Oct 6, 2001 | 01:24 AM
Chunger's Avatar
Yep... to add to Shadows comments... Single and dual piston calipers have the piston(s) on one side of the caliper so the other side is just a 'brace' (for lack of the proper term). On 4, 6 or 8 piston calipers, half the pistons are on the either side... so it has to be 'wider' overall.
Old Oct 6, 2001 | 05:37 AM
CoOlKidS1979's Avatar
Since I have the Wilwood kit I would have to reccomend them over the Brembos because they are $1000 cheaper, and you lose around 10 pounds a wheel, while I think the brembos add weight. They only problem is that the calipers are so damn wide, I know of one person who couldnt get them to clear with his 18" rims. On my 17"s you can slide a business card between the caliper and the rim and the business card will be held in place, but they stop the car fast, look good, and there is no fade.
Old Oct 6, 2001 | 10:50 AM
max'n out's Avatar
Yeah I'm fully aware of how brakes work and don't need a lesson. Some 4 piston calipers are pretty small in comparison to other ones.
Woun't it be possible to get a spacer out on the 17" to allow them to fit the way you did for your 19"s.
Old Oct 6, 2001 | 12:52 PM
mrb23's Avatar
Damn, what kind of 18s did he have that the Wilwoods wouldn't fit? I'm seriously thinking about upgrading my brakes now
Old Oct 6, 2001 | 04:42 PM
1MAX2NV's Avatar
It's all about the width, the offset and the style of the wheels. 1. 18X8.5 will have an extra 1/2" clearance compare to 18X7.5. I don't think any 7.5" wide rim will clear any of the big brake system out there for the maxima. 2. +35mm offset will have that extra 5mm compare to +40 offset. 3. The fatter the lip, the less chance it will clear. 1" shouldn't be a problem but anything bigger you better have 8.5" or even 9".
Old Oct 6, 2001 | 08:36 PM
Shadow's Avatar
Probably not, it would clear the brakes, but the wheels would be spaced out so far they'd stick out slightly.
Old Oct 6, 2001 | 08:46 PM
max'n out's Avatar
Why would they stick out I could just space the factorys out as far as my 19"s go whitch is flush.
Old Oct 6, 2001 | 08:57 PM
Shadow's Avatar
Spoke design. Some wheels have to be spaced out further than others to clear the brakes, it all depends on the design of the spokes. The factory 17"s have pretty thick spokes that would need a lot of spacer to clear. Even a lot of aftermarket wheels won't clear with spacers. Ming (MAC) had a set of 18" AV3's witha 46 offset. He had to space them out 15mm (a lot) to clear and the wheels ended up sticking out. So he ended up getting Volk GTP's which did clear. It's all about spoke design.
Old Oct 6, 2001 | 09:03 PM
philpoe's Avatar
4 Maximas and counting
wrt Wheel width and clearance
The Wilwood kit was _meant_ to fit under the stock 4th gen 16" SE wheels. (it didn't).
As was said in another post, it's about width, offset and spoke design. There's someone out there using 16" Kosei K1s over 300ZX brakes, and of course, 300ZX rims fit over 300ZX brakes. I have a polished set that I plan to use over my own Wilwood kit.
All that being said, 4 piston calipers pretty much have no shot of getting under the 17" 5th gen SE rims
Mar 12, 2020 12:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
