Rims question
Old Oct 3, 2001 | 06:22 PM
black019's Avatar
Rims question
okay i just got my rims in the mail today and i was planning on putting them on tonite. is there anything i should know before i attempt to do this? will i need to get my car aligned? any input would be great. thanks.
Old Oct 3, 2001 | 06:24 PM
Sprint's Avatar
are they already mounted on tires?
if not .. a shop might need to do them
you don't need an alighment.. if you have them on tires already.. you might need hub rings?? not sure.. are they already balanced?
if all is good it will be like changing a flat tire.. 4 times
Old Oct 3, 2001 | 06:29 PM
mrb23's Avatar
Make sure you get a good balancing somewhere. You might need alignment even if your alignment was good before your new rims, but balancing is essential!!!
Old Oct 3, 2001 | 10:35 PM
black019's Avatar
well, tires are already mounted on them and they were on someones car before so they should be balanced. i was just wondering if there was going to be anything I should be aware of. what is a hub ring or whatever was mentioned earlier? never heard of that before...
Old Oct 3, 2001 | 10:48 PM
Nealoc187's Avatar
SLOW
some wheels come with a hub-centric ring that makes sure the wheel is centered on the hub (thats why its called a hub-centric ring). it makes sure the lugnuts are perfectly aligned through the holes so that they all get tightned down evenly. its not a necessity, but it helps. I lost my 2 front hubcentric rings last week at the track, i was ****ed.
Old Oct 4, 2001 | 02:08 AM
black019's Avatar
woo hoo! put my rims on. looks nice. I took her for a nice little test drive. ride seems a little harder and I feel a little more resistance on the steering wheel now. maybe I do need to go and get the car aligned and/or balance the tires. took her up to 120 and the wheels didnt fall off so I would say it was successfull!
Old Oct 4, 2001 | 02:19 AM
Max2000's Avatar
also make sure
you retighted them after few hundred miles...
Old Oct 4, 2001 | 02:35 AM
black019's Avatar
Re: also make sure
will do. when I have them aligned and balanced Im sure my mechanic will torque them correctly...
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
