Very Good Y-Pipe Question
Old Oct 9, 2001 | 05:15 AM
deezo's Avatar
Very Good Y-Pipe Questions
I just need to know how it will effect my emissions. Will it set off the Engine Check Light? Has anyone failed inspection because of using it?
Also my car is a Cali Spec, will this make any difference?
I just need the facts.
Thanks.
Old Oct 9, 2001 | 05:23 AM
mzmtg's Avatar
Minister of Silly Walks
You should be ok. The main purpose of the cats in the OEM y-pipe is to cut startup emissions. They are closer to the exhaust ports, so they will heat up and "light off" sooner. The main cat should be able to keep you clean after it warms up. Drive around for at least 45 minute before you go, to make sure it is good and hot.
However, if the look under your car to make sure you have all your cats, there may be a problem.
Then again, I don't have a y-pipe, so this is all just a guess....
Old Oct 9, 2001 | 05:29 AM
redmaxpa007's Avatar
i SeE what you did therE
that is true..
i am getting my y pipe in a week... finally..
will let you know..
Old Oct 9, 2001 | 05:31 AM
deezo's Avatar
Hmmm!!! I could go to a center where I know they won't look under the car to check for the cat or maybe I never noticed it. Thanks for your input.
Old Oct 9, 2001 | 05:34 AM
apexi's Avatar
just make sure they dont look under your car!
Old Oct 9, 2001 | 05:35 AM
deezo's Avatar
One thing I know to keep in mind now.
Old Oct 9, 2001 | 05:44 AM
Confused's Avatar
Permanent Maxima.org Resident
Many people have passed emmissions without a problem. Generally, make sure the car is warm bofore going, if your really worried do an oil change before that 30 minute drive.
In NY I have found that if you don't go to Nissan, and have the inspection done at a local mechanic (don't know if Mass has the same setup)they don't really know the pre -cats are missing
My $.02
Old Oct 9, 2001 | 05:45 AM
Stealth Max's Avatar
Re: Very Good Y-Pipe Question
Thanks.
The y-pipe will free up your air flow. The stock one is very restricted. The engine light will not go on if installed properly. I passed MA emission/inspection test so far without any problem.
Old Oct 9, 2001 | 06:47 AM
deezo's Avatar
My $.02
We have local mechanic stations here too.
Old Oct 9, 2001 | 08:47 AM
Sonic's Avatar
Old Oct 9, 2001 | 10:42 AM
deezo's Avatar
Originally posted by medicsonic
Old Oct 9, 2001 | 03:36 PM
Sonic's Avatar
Someone's not in the loop.
Old Oct 9, 2001 | 03:38 PM
SuDZ's Avatar
What kind of Pipe you getting?
SuDZ
Old Oct 9, 2001 | 04:26 PM
Aaron92SE's Avatar
NWP Engineering.com
Does anybody know if the same thing applies to a 92 Maxima SE? I am getting a Y-Pipe very soon and I'm also wondering if I will have a problem with inpections or emissions. Thanks.
Old Oct 9, 2001 | 04:36 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
finally deez your gonna do something to your beast. i passes emmisions fine with a WSP y-pipe and no shop will know you are missing the pre-cats because they don't know nissan's that well. most places think they don't even make performance parts for a maxima. if you get a cali spec pipe you will have no check engine lights or anything. what kind are you gonna get???
Old Oct 9, 2001 | 05:37 PM
deezo's Avatar
I don't know yet.
Old Oct 9, 2001 | 05:49 PM
Synki's Avatar
Dana, i have a 99 cali spec myself & i am using a Stillen Y-pipe right now.
You will pass emissions w/ it. The Y-pipe for the 4th gne cali models only eliminate 1 precat & not both. The precats are only there for polution control during cold start-ups. Drive the car around for 10 mins and there will be no difference in emissions at all.
No, you will not get any CEL on from this. As long as your 02 sensors are plugged back in & not damaged, you will be fine.
Also, with the cali spec models, you can run w/o a cat (eg. hollowed out cat or test pipe) and no CEL lights will occur. That is b/c we do not have any 02 sensors in anywhere from the cat all the way back.
I hope this helps.
Old Oct 9, 2001 | 06:01 PM
Sonic's Avatar
I hope this helps.
Hollowed out cat= less power, might as well get a straight pipe at that point.
Old Oct 9, 2001 | 06:02 PM
Synki's Avatar
Not unless your on the bottle.
Old Oct 9, 2001 | 06:20 PM
deezo's Avatar
Thanks Synki, it does help. Med, do you have a Y-pipe?
Old Oct 9, 2001 | 06:25 PM
Sonic's Avatar
Maybe...
Old Oct 9, 2001 | 07:12 PM
yourmove's Avatar
Hey Deezo & guests, I've had a y-pipe&h/f cat added to my cat back for a little while now. I'm due for inspection this month! I'll definately keep you posted!
Old Oct 10, 2001 | 04:46 AM
deezo's Avatar
Yourmove, keep us posted. If you can find this thread post it here. If no, ttart a new one to my attention.
Thanks.
Old Oct 10, 2001 | 04:48 AM
deezo's Avatar
Maybe...
Old Oct 10, 2001 | 10:09 AM
Sonic's Avatar
Old Oct 10, 2001 | 01:58 PM
yup, and i have a fed spec with a hollow cat and it works fine with the CEL. even though i have a O2 after the cat.
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Greenmaxspeed
Aug 31, 2015 09:06 PM
stromm
Aug 27, 2015 04:13 PM
