under dirve pulleys.... how much hp do they free up?
Old Oct 9, 2001 | 06:23 AM
redmaxpa007's Avatar
i SeE what you did therE
ok..how much hp do they free up? yes, i have read how much they free up, but i want testimonials... from real people
i am lookin into getting them.
what part numbers are the new belts that i will have to get?
i am coming up on my 60,000 mile mark, and since i will be changing belts, i figure, why not add some hp, plus this is a mod the wife won't see, so i can't get in trouble.. hehe
Old Oct 9, 2001 | 06:25 AM
UMD_MaxSE's Avatar
Got Bent?
I bet they are good for a few hp... You won't feel anything dramatic, but you do feel it. The engine revs a bit quicker, especially at lower rpms. I think Hogan is running a GD on them right now with belts....
Old Oct 9, 2001 | 06:30 AM
yongjun's Avatar
How hard was it to install on your max.
I think my friend wants me to help install one on his automagic max.
Old Oct 9, 2001 | 06:34 AM
UMD_MaxSE's Avatar
Got Bent?
be careful with the belt tensioners... You probably need a gear puller also. I got mine put in at a shop... but the install didn't look too hard. The pulley bolt will take some torque, but with air tools, it should be ok
Old Oct 9, 2001 | 07:06 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
You'll still be slow.
Check my site for belt part numbers (performance page).
Old Oct 9, 2001 | 07:11 AM
thanks, .......focker..
Old Oct 9, 2001 | 08:25 AM
Sprint's Avatar
they give 1 hp low end and loose 1 hp in high end.. they are a waste of money
Old Oct 9, 2001 | 09:26 AM
got rice?'s Avatar
about [_____________________________________________] this much more power
Old Oct 9, 2001 | 09:31 AM
hey.. i am serious.. this time.. i am really thinking about buying them..
Old Oct 9, 2001 | 10:46 AM
nismo2020's Avatar
Needs non-Maxima Friends
udp
i swear the udp has got to be the most contravsial thing ever made for the max.
Old Oct 9, 2001 | 10:50 AM
maxmizd27's Avatar
Haven't had mine dynoed, but I can see it on the tach. Revs up to over 4K in no time.
Old Oct 9, 2001 | 11:34 AM
97GreenMax's Avatar
Old Oct 9, 2001 | 11:39 AM
nismo2020's Avatar
i will dyno
i plan on getting a udp very soon. to bring an end to this i will make two good runs on the dyno then back the car off put the udp in and re-dyno it. that way we(I) will have good numbers to see wassup with it.
Old Oct 9, 2001 | 02:30 PM
emax02's Avatar
There is absalutly no need to use a gear puller. My max had 99K miles on it when I put my UDP on and the pulley came off in my hands, I did not even pull on the thing really, it just fell off. Air tools whould definalty make getting the pulley off much easier but I used a 2 foot breaker bar/spinich and just took about 5 swings at at my wrench and the bolt loosened right up. I attempted using brute force but that did not work at all.
Old Oct 9, 2001 | 03:00 PM
got rice?'s Avatar
Jeff, shoot me a message when I'm on AIM for some objective data on the pulley.
Old Oct 9, 2001 | 03:44 PM
SuDZ's Avatar
I think it is supposed to be like 5 - 8 HP or so but I dont have the magazine with me right now that I saw somethign intresting in. It was in last months Sport Compact Car and they were using it on Project Ford Focus. They had an equation in there that let them see how much HP or torque they were gaining throughout the gears. If I find it tonight I will post it on here.
SuDZ
Old Oct 9, 2001 | 07:07 PM
JDM4LIFE's Avatar
i installed the udp myself. except for the 45 minutes downtime of being given the wrong size belts from autozone and having to drive to it to get the new ones and all, it took about hour and a half. there's not a lot to it really. just make sure everything is done according to instructions so you don't do something insane to have the crank out of whack. i noticed it revved more freely. it didn't really add much bhp, but if this makes sense, my car felt like it accelerated much smoother. it gained a little on bottom end for sure... i've heard from several that it's more effective on 5-speeds.
Old Oct 9, 2001 | 07:10 PM
KLoWnPR109's Avatar
is it true that you shouldn't get a UDP if you have a system. I remember reading this a while back.
Old Oct 9, 2001 | 07:31 PM
yourmove's Avatar
Re: under dirve pulleys.... how much hp do they free up?
I put one on my 99 se 5-spd. with my wife (to step on the brake) and had no need for a gear puller or air tools. However, the crank bolt is on there good! I bought my kit with belts and did not notice the sizes. It's easy to do yourself. The only probs. is the pwr steering pump, just figuring out the tensioner hardware. I noticed a nice increase and do suggest this product. The only draw back...... You'll be used to the gain quick!
Old Oct 10, 2001 | 12:35 AM
La Jolla Max's Avatar
Budget Exhaust has a dyno chart for the UDP:
6hp and 10lb-ft.
Old Oct 10, 2001 | 01:14 AM
black019's Avatar
udp is pretty hardcore
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
