tranny shifts hard into second
Old Oct 9, 2001 | 04:05 PM
Maximum Performance's Avatar
I have a 96 max with auto transmission
it has 97,000 and shifts very hard (with a jerk) into second
is there anything i can do about it?
the car is all stock...but it was driven really hard
i got it when it had 20,000
Old Oct 9, 2001 | 04:10 PM
Craig Mack's Avatar
All YOUR grammer belong to me
It probubly does this most often in the mourning, correct ? It jerks hard then b/c the tranny has to warm up. Perfectly normal.
Do you feel it also when driving normally, maybe a little less than in the mourning ? Perfectly normal. The fact of the matter is...
YOU'VE GOT A MAXIMA SON! The max has an identity crisis between a sedan and a sports car. The sporty shifting is just one of the crisis points, and a point you should LOVE !!
Old Oct 9, 2001 | 04:15 PM
yeah it jerks hard when it is cold but when it is all warmed up it jerks a little to
before when it was never it was nice and smooth...
Old Oct 9, 2001 | 04:46 PM
Sonic's Avatar
Get your line pressure checked.
Old Oct 9, 2001 | 07:52 PM
ok is this the one that goes to the tranny cooler?
where is it ? what should i check for?
Old Oct 9, 2001 | 07:56 PM
Sonic's Avatar
You pretty much have to go to a tranny shop in order to do it.
Old Oct 9, 2001 | 08:04 PM
black97max's Avatar
You could always get Don's Valve Body to soften the shifts up for you
Old Oct 9, 2001 | 08:14 PM
Sonic's Avatar
Right, softer.
Old Oct 10, 2001 | 01:20 AM
black019's Avatar
you could probably get a few testamonials on that one too
Old Jan 10, 2002 | 11:13 PM
MigthyMax's Avatar
Hi
Did you ever fix the tranny problem... I'm having the same problem with my 96 Max
Old Jan 11, 2002 | 05:13 AM
mzmtg's Avatar
Minister of Silly Walks
That's not a "bug", It's a "feature."
Old Jan 11, 2002 | 09:06 AM
sinewave's Avatar
There are two plugs in the side of the A/T that you have to remove to check line pressures; definately a shop job. You ought to check the dropping resistor; if it is bad or disconnected, you will get very hard shifts. It's a silver rectangular block mounted horizontally on the left (driver's side) strut tower and has a 2-wire connector on it.
Unclejunebug
Apr 2, 2016 05:42 AM
fx4five
Oct 18, 2015 06:57 PM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
