Lowered the car but...........only 1 corner :(
Old Oct 9, 2001 | 11:38 PM
Nismo's Avatar
I was installing my KONI/Apex(1.6" drop) tonight but ran into a little problem. I needed a foot lb torque wrench....I bought an inch pound torque wrench so I ended up doing the install on 1 corner only but not torquing it down I just tighten it up just to keep it together. Im not going to drive it until I get the proper torque wrench. I need to know the proper Torque specs to everything since PerformanceX who hosted the instal is not online for some reason anymore. Does anyone know another site that has the install? maximadriver doesnt show the whole install.
Old Oct 9, 2001 | 11:40 PM
black019's Avatar
thought you were gonna say u had a flat tire
Old Oct 9, 2001 | 11:48 PM
Bags's Avatar
VG Ridah's Biatch Hoe
not to be funny
BUT , you know you can convert inch lbs to foot lbs right? every foot lb is equal to 12 inch lbs. i am not saying you did not know this , but just checking. your torque wrench might not be big enough either.
Old Oct 9, 2001 | 11:57 PM
Nismo's Avatar
Re: not to be funny
I know about the conversion but my torque wrench doesnt go that high.
slammed95- yea I already rented the spring compressor but I only gave them $50 unlimited rental for the compressor only. I already bought a torque wrench but it was obviously the wrong type and couldnt go back to exchange it because I started working on it late at night so my only choice was to do one corner without torquing and just leave the car as-is until I get the proper tools.
still need the torque specs if anyone has them please.
Old Oct 10, 2001 | 12:09 AM
Bags's Avatar
Re: Re: not to be funny
still need the torque specs if anyone has them please. [/B][/QUOTE]
sorry was working on the info... the three bolts on top of the front strut assem is 29-40 ft lbs getting the rest
Old Oct 10, 2001 | 12:11 AM
Bags's Avatar
the rear shock absorber mounting seal is 12-14 ft lbs what else do you need? man i need a hobby
Old Oct 10, 2001 | 12:21 AM
Nismo's Avatar
Re: Re: Re: not to be funny
what about the 2 bolts that go on the bottom of the front strut connecting to the rotor assembly? also the top one where the top hat is is 50 lbs? tires lugs 85lbs? koni strut to the stock strut is 65? am I right?
Old Oct 10, 2001 | 12:39 AM
Bags's Avatar
Re: Re: Re: Re: not to be funny
knuckle to strut 103-117 ft lbs
confused about what the top hat is. i am looking at a nissan service manual piston rod lock nut?
tires lugs 85lbs?
72-87 ft lbs
confused about what you need? the strut housing or what?
Old Oct 10, 2001 | 01:05 AM
Bags's Avatar
sorry
bed time i will check in a few hours
Old Oct 10, 2001 | 01:10 AM
Nismo's Avatar
Re: Re: Re: Re: Re: not to be funny
yes, front strut housing and also the nut on the top of the strut. thanks
Old Oct 10, 2001 | 09:18 AM
Bags's Avatar
Re: Re: Re: Re: Re: Re: not to be funny
[QUOTE]Originally posted by Nismo
[/QUOTE
the nut on top of the strut is 43-58 ft lbs
the front strut housing to where it connects to the knuckle of the wheel hub is 103-117 ft lbs.
do you need any back numbers?
Old Oct 10, 2001 | 05:00 PM
Nismo's Avatar
Re: Re: Re: Re: Re: Re: Re: not to be funny
do you need any back numbers? [/B][/QUOTE]
where did you get the specs? can you please post the #s for everything I need for the install so I dont have to keep bugging you? thanks
Old Oct 10, 2001 | 07:51 PM
Bags's Avatar
i own the nissan factory manual
where did you get the specs? can you please post the #s for everything I need for the install so I dont have to keep bugging you? thanks [/B][/QUOTE]
i have the factory manual. i do not mind helping , i have gotten lots of help here i will pos everything on the back that i can find in the next thread. your not bothering me , i have not done my supension yet, i just ordered kyb agx and eibach springs. so maybe i will be where you are in a month. anyway back to what you want to hear.
Old Oct 10, 2001 | 07:57 PM
Bags's Avatar
Ok here we go working from the bottom to the top of the shock
the bottom bolt that connects to the torsion beam is 72-87 ft lbs
IF you disconnected the abs sensor it's TQ is 18-25 ft lbs
the 2 bolts on the shock absorber mounting bracket 12- 14 ft lbs
and the top nut under the shock absorber cap is 13-17 ft lbs
again i have not done this so i do not know what else would be required. hope that is everything you need if not i'll be wandering around.
bags
Old Oct 10, 2001 | 11:37 PM
Nismo's Avatar
thanks! well I think thats all I need for now
Lakersallday24
Jun 16, 2019 01:35 AM
twotonezed
Aug 16, 2015 08:10 PM
soon2ownmax
Aug 13, 2015 02:19 PM
classymax420
Aug 6, 2015 06:35 PM
laparka66
Aug 6, 2015 09:36 AM
