Englishtown, battle of the imports....i ran a 14.4!!!!!
Nealoc, VQDriver, look at your wheels. VQDrivers max is pushing 15 * 6 (or 6.5?) wheels whereas Neal is pushing 17*8s. Quite a bit more rotational mass to turn in Neal's car. Smaller wheels will really help your 1/4 mile times.
DW
DW
DW
DW
Originally posted by La Jolla Max
how much pressure were you running in the fronts again?
cool
Well... then this is the 2nd fastest 4th gen run next to Jeff K for an N/A Max running on street tires
Now imagine VQdriver with all the mods Jeff K had. That would be interesting. Can an N/A 4th gen break into 13s? Yea, I know it probably can, but without serious engine work?
Originally posted by SprintMax
Jeff K never used slicks.. he had DR's
http://integra.vtec.net/geeser/megamax/Drag_tips.html
If you look at his top time-slip is says slicks.
Is there a big difference? Even DR's will do ya' better than street tires.
Re: cool
Re: Re: cool
Originally posted by VQdriver
what is Jeff K's setup?
I think at the time of his best run, he had a 95 with a CAI, full exhaust, JWT Chip and slicks.
Re: Re: Re: cool
Originally posted by ejj5875
Check out the link in my post above. That's his website.
DW
DW
One other question, what were the atmospheric conditions, temp, humidity and pressure. If you don't know exactly, just estimate.
Good job man, you've raised the bar in my mind.
Ahh, then maybe it was because he had a few mods and you were stock. Looks like you guys are pretty much the same then. Intake AND Y on your setup should really bring down your numbers.
DW
DW
Originally posted by Nealoc187
Nope thats not it, I was on aftermarket 15x6.5 wheels on 205-65-15 rubber at 20 psi. Though the tires are crappy, that doesn't have any bearing here, since my 60' was actually better... 2.209 vs his 2.24, his car is just plain making more power, especially in the first 330' feet where the low-mid range power is crucial. That's to be expected though because I'm stock. I'm still very impressed with his times, and it has made my case for getting a y-pipe... now if only Josh would email me about his Cattman.
how about 12s? these are maximas
