How to make an Nissan Consult Interface cable?
Old Sep 14, 2007 | 03:52 PM
clh288's Avatar
I have been searching the internet for the last few hours looking for planes on how to make my own ECU to laptop cable. And I have found a good set of planes for the circuit that is needed to be made (Link). But were is a good place to by the parts? Things like Breadboard, resistors and capacitors are easy to find. But does any one know were to get a ECU Consult/DDL connectors or the chips, ect.
Good sites I have found
http://www.plmsdevelopments.com/consult_if.shtml
http://www.slippyr4.com/Read.aspx?post=11
Old Sep 14, 2007 | 03:56 PM
NmexMAX's Avatar
dot dot dot ...
I have one. It came from my Cipher. What software are you going to use to utilize this cord?
Old Sep 14, 2007 | 04:03 PM
made in china's Avatar
http://www.mouser.com/search/Product...ey829-12110252
Old Sep 14, 2007 | 04:05 PM
clh288's Avatar
I have a copy of Nissan DataScan, that seems the best and I think someone gave be a copy of PCMSCAN that is around some were.
Old Sep 14, 2007 | 04:06 PM
clh288's Avatar
Originally Posted by made in china
I assume that is the ECU connector?
Old Sep 14, 2007 | 04:27 PM
ThurzNite's Avatar
wow, cheap! how much is shipping?
Jae
Old Sep 14, 2007 | 08:34 PM
OBDII male connector. They also have OBDII Female, and OBDI Male/Female connectors. I just happened to have that one bookmarked, I used that connector for my swap.
Old Sep 14, 2007 | 10:40 PM
andrei3333's Avatar
This is a good idea, but using a microcontroller and programming it with hex machine code is challenging. i remember some of it from college, and i may have some notes and books still if i dig around, i can try to help you with the code if you decide to go along with it.
How do you convert the hex code back into the Nissan understandable Ecu codes ?
It would be easier to translate the code if there was a possibility to hook up the scanner to the laptop through an RS232 jack, no ?
Old Sep 15, 2007 | 11:34 AM
Depends if it is Consult-I or Consult-II. I think Consult-I code has been broken, but AFAIK Consult-II code is way too difficult to decipher. I found a good link on the subject recently. Basically, auto manufacturers mix OBD codes with their own proprietary (like Consult) data. The OBD codes are open source, the manufacturer codes are tightly guarded.
So, depends if he wants a Consult-I or -II. I don't think the connector in my link works with Consult-I, didn't Nissan make their own data port for Consult-I?
Old Nov 2, 2007 | 07:28 PM
clh288's Avatar
I spent about 3 hours yesterday making up the parts list to make one and then someone was selling one used for 25BIN.
I looked every were on mouser and they don't have any obdI nissan connectors. But a makeshift one can be made from other 14 pin connectors.
Cant wait to get it, going to mount it to the fuse box and roll the usb cord under the steering wheel.
BTW has anyone tried one of these, I use my laptop for GPS and music too so having one of these would be awesome. Any good places to mount it? http://cgi.ebay.com/7YEARS-ON-EBAY-C...QQcmdZViewItem
this site has a list of software to use http://www.nissanforums.com/tools/12...softwares.html
Old Nov 7, 2007 | 10:46 AM
SVI30's Avatar
You can use Excel to convert binary and hex to dec; HEX2DEC, BIN2DEC etc. But these are engineering functions that a normal MS Office installation does not have. So you will need the distribution CD to add it.
I used these to recalculate the check sum in the SPD on the PC memory DIMMs.
schmellyfart
Sep 25, 2015 04:47 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
