IS this a good deal?
Is this a good deal to have all this stuff installed for under $600 OTD?
Also: anything else I should add or do while getting this stuff done?
THanks !!!!!!
Schneider Motor Sports – Jay
614-921-3278 @ 590 N Wilson Road, Near U Store and Sell
UDP(black) w/belts
Unorthodox Racing Lightweight Flywheel
ACT Street Disc
RT Cat
5.5hours ($45/hour) + tax
=$247.50 + tax
+ Quaife Torque Biased Differential
+ Place Racing Heavy Duty Polyurethane Engine Mounts
+ Misc Parts Install
=?? 8 hours X $45 = $360 NOPE
=11-12 Hours => Quoted Under $600 OTD
***Make sure they set the bearing preload and reuse the gear fluid. Make sure there’s no silver, milky, or dark stuff in there. Use a magnet to see if there are any shavings***
Misc Parts Installed, I supply:
new bearings
possibly shims
speedometer gear
Tranny seals: input shaft, 2 driveshaft, and possibly gear shifter shaft
UDP: Replace the front oil seal, part # 13510-31U00
THanks !!!!!!
UDP(black) w/belts
ACT Street Disc
RT Cat
=$247.50 + tax
new bearings
possibly shims
speedometer gear
Why not
I'd hate to have to install all that. I think since you had the money to buy all the stuff, you probably have good money to go around. I do a lot of my own installation because it's a hobbie of mine and I like to install each mod one by one, as I get them. I'm terribly scared to work on anything with my transmission except for the Short-throw shifter. But a differential is not something I'd like to play with, nor the engine mounts for that matter. I assume you need a motor hoist to hold the engine. Some of those things I'd install myself, but since you are going to have the others professional done go ahead and have it all done.
thats a total of 13.5hrs for all that.. i dunno about that, specially the differential & flywheel ..
motormounts ive heard can be changed w/o hoisting the engine, but the way we did them on my bosses mustang was to hoist.
if all the labor is done at once, i think 13.5hrs might be too much. its not like theyre gonna put it back together then start all over again.
ALL that installed for 11-12 hours, quoted to be under $600 with tax and all.
