Transmission Cooler
Old Oct 21, 2007 | 07:20 AM
kevin007's Avatar
Transmission Cooler
Is anyone out there using a transmission cooler if so would you post up some details? Thanks!
Old Oct 22, 2007 | 03:45 PM
max ride 41's Avatar
are you lookin to race. and, is that red max yours??? if so, you should know allready that there used for racing primarily, but can be used for daily drivers.
Old Oct 22, 2007 | 04:10 PM
jonmandude's Avatar
Actually transmission coolers were designed for towing applications
Old Oct 22, 2007 | 07:15 PM
z32drifter's Avatar
I've had a trans cooler on my Maxima for about 5yrs and the trans is still going strong. I'm using a Hayden cooler, I don't remember the model number. I have it setup on the return line from the radiator cooler to the trans.
The cooler adds some extra fluid capacity and ensures the fluid stay cool for days like this....
They are fairly simple to install, in a northern climate you may want some type of thermostatic bypass to make sure the fluid reaches proper temps during the colder months. I'm in Florida so did not feel that type of setup was needed.
Old Oct 23, 2007 | 03:12 AM
kevin007's Avatar
The details I wanted was who makes them, model number, performance.
Thanks for the info Z32dritfer, by the way those pics were hot, it looked like you had lots of fun.
Old Oct 23, 2007 | 03:54 AM
Bonka's Avatar
Schnell kaputt
I'm using one from B&M, I think the model number was 70268. They have a built-in bypass so when the weather gets cold the ATF bypasses the cooler completely so it heats up sufficiently. Along with Amsoil ATF, I figure it's good insurance to prolong the life of the tranny. 1-2 shifts are firmer but the rest of the shifts are smooth.
Old Oct 23, 2007 | 05:49 AM
kevin007's Avatar
Thanks for the info do you have a website for the B&M Cooler?
Old Oct 23, 2007 | 07:54 AM
Tuna's Avatar
I picked up my B&M cooler from the local AutoZone about three years ago. They had to order it for me but it only took two days. Call your local auto parts stores. If I remember correctly, it was only about $80 or so. But it's a good investment if you plan on keeping the car and wish to prolong the life of the tranny.
Old Oct 23, 2007 | 01:44 PM
Bonka's Avatar
Schnell kaputt
I ordered mine from Jegs. www.jegs.com About $60 I think.
Old Oct 23, 2007 | 06:21 PM
LatinMax's Avatar
I second that. www.jegs.com is where got mine also.
Close up
Old Oct 24, 2007 | 10:40 AM
Synki's Avatar
When I had a trans cooler in my Maxima, I used a Haydens 403X trans cooler. I usually disconnected it during winter since I did a lot of short distance driving. All you do is tap into the trans cooler lines that runs to your radiator. You will need some additional clamps and hose. The cooler was mounted infront of my a/c condensor. I had no cooling issues whatsoever. The cooler was like $45, then again that was over 7yrs ago.
Old Oct 24, 2007 | 11:59 AM
ROCKART's Avatar
wants an I35
yea im just a daily driver but i drive pretty hard sometimes.
i also live in the tire melting heat of FLORIDA. i was thinking about putting additives in the coolant and ATF. i see them in autozone but never bothered to ask how they work.
is this recommended for such a hot climate?
Old Oct 24, 2007 | 01:13 PM
Synki's Avatar
To be honest, your best bet is to just do the fluid changes when needed/more often depending on driving conditions.
You are def better off getting a trans cooler if you drive hard or do any kind of racing.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Pied
Sep 26, 2015 03:29 PM
