Yokohama AVS DB tire. Please post your opinions.
Hello guys. I used the search and found a little info on the tire, but not enough. I'm basically stuck between two tires.
Yokohama AVID Touring and Yokohama AVS DB. The DB obviously will have better performance, but what I'm more interested in is that if it will be quieter than the Avid Touring. The price difference is only $20 per tire (205/60/15) so I'm trying to see if I should just get the DB. If you could post how it rates in quietness vs. other tires you used it would be great.
Anton
Anton
I think I'd go with the Yoko Avid Tourings, the AVS dB really makes the difference when you are runnning a larger tire size, when running 18s it makes a huge difference over lets say a Pirelli P7000, but on 15s, I think it wont make that big of a difference
Re: Yokohama AVS DB tire. Please post your opinions.
Anton
Anton
My only complaint so far is that with aggressive driving in curves the tires sqiurm with the intial turn-in. When I am going fast and start going into a curve and the car shifts it weight, the tires feel like they slide about an inch and then start to stick. It's like I caught the tire sleeping at the switch going into the turn and then the tire wakes up and handles the rest of the curve fine. Again this trait only shows up in aggressive driving.
REDinLV
08-15-2024 12:30 AM
04-16-2020 05:15 AM
