wood dash instalation
Old Oct 24, 2001 | 07:58 AM
kjpierce's Avatar
any tips on installing a wood dash trim for a 00' or 01' maxima. any suggestion on where to buy a kit? i looked at exotic wooddash and wooddash .com
both seem reasonable. thanks
Old Oct 24, 2001 | 08:04 AM
amixam98's Avatar
Needs non-Maxima Friends
www.woodtrim.com....
Old Oct 24, 2001 | 09:00 AM
Maximizd's Avatar
Take your time when you are installing it. It should be done on a warm day or indoors. The parts and surfaces should be gently warmed up with a hair dryer. Pre fit everything before you expose the adhesive - you only get ONE chance to get it right. The hardest part on the 2K is the piece above the shifter because it has multiple curves. You may want to bribe a friend to help out, a second set of hands can be useful to hold the dryer while you position the piece.
Old Oct 24, 2001 | 04:32 PM
MaineMax's Avatar
When I put mine in two of us did the install. One to hold the hair dryer, one to work with the kit. Total install time 20 - 25 min.
Check your pieces first to make sure that they are all there.
Easy job to do.
Old Oct 24, 2001 | 10:54 PM
BigDogJonx's Avatar
If you are weary about do this install, might want to think about a MOLDED kit. That way you dont have to worry about heat guns and sticky tape and only getting once chance, plus it looks better cause it looks more OEM, and not like a piece of wood STUCK on top of the old moldings
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
rnb754
Sep 14, 2015 11:39 PM
2kmaximel
Sep 10, 2015 08:13 AM
spidgeon
Sep 9, 2015 03:36 PM
