2002 mixima 0-100 KM/h ....
Old Oct 24, 2001 | 08:03 AM
Tri-lite's Avatar
I read in the 2002 auto-guide car book that the 2002 maxima does 0-100 KM/H in 7.5 seconds ?! and the altima (with the 3.5) does 7 seconds... is this true ?!?!
(BTW 60 mhp = 96 km/h ... not quite 100 so 0-60 time is slightly smaller .2 or .3)
Old Oct 24, 2001 | 11:11 PM
BigDogJonx's Avatar
Yeah, because the altima is a lighter car
Old Oct 24, 2001 | 11:14 PM
SWEETSOUND2001's Avatar
Maxima weighs a whopping one pound more!!!
Old Oct 24, 2001 | 11:28 PM
AznWontonboy's Avatar
they probally tested a 5 speed manual altima and a 4speed auto maxima... I35 Auto tested at 7.0 Seconds 0-60mph.
Old Oct 25, 2001 | 06:08 AM
Kehops's Avatar
Re: 2002 mixima 0-100 KM/h ....
(BTW 60 mhp = 96 km/h ... not quite 100 so 0-60 time is slightly smaller .2 or .3) [/B][/QUOTE]
I don't think that's a very accurate assumption. 0-60 is more like 0-99.5km/h and even if it was then 4km/h wouldn't add 0.3secs.
Also, the Altima was tested at approximately 6.0 seconds 0-60 and 14.5 seconds 1/4mile. The Maxima isn't too far off those times.
Old Oct 25, 2001 | 07:13 AM
MONTE 01&97 SE's Avatar
I dont think those times are accurate considering that they got the I35 to 60m in 7 flat. The Max weighs less and should do it in about 6.7 or 6.8 for the auto. An unofficial test of my 2k I got it to 60 in 6.72 sec before it was broken in. Now the 6spd is a different story!
Old Oct 25, 2001 | 07:14 AM
Kashoggio's Avatar
ok the maxima has 16 more hp , it weighs about the same and with the 6 speed, its going to have better times then the altima
Old Oct 25, 2001 | 08:26 AM
bigbadboss101's Avatar
i35 performance
The magazine showed that the I35 has 40 hp on the Mercedes, and 100 lbs lighter. Yet, the performance were almost identical. That would be the case of bad gearing?
Old Oct 25, 2001 | 01:11 PM
Black VQ's Avatar
They must be granny drivers or something...
I've never seen times that slow for the Maxima and Altima before. I know that the Maxima had to travel farther and driver probably had to upshift @60mph, but I doubt that it would add another .9 seconds. The same issue with the Altima. How could all of that add another .8 seconds? I can't think of anything else, unless they just can't drive.
Hopefully those are the times for the automatics in both cases. That's my only other guess.
Old Oct 25, 2001 | 01:35 PM
MaDxKiLLa's Avatar
Re: i35 performance
Well we have FWD
which makes us slow...
Old Oct 25, 2001 | 02:38 PM
dwapenyi's Avatar
Re: i35 performance
Comparing a Mercedes E320?? The Benz has a 5 speed auto whereas the I35 is a 4 speed auto, still. The gears will definitely help, as it did the Mercedes.
DW
Old Oct 25, 2001 | 06:55 PM
emax02's Avatar
B.S. #'s, leave it at that.
Old Oct 25, 2001 | 09:39 PM
Mercedes
the one they tested was the C320. 215 hp, 3439 lbs, similar 0-60 and 1/4 as the I35. November's Motor Trend.
Old Oct 26, 2001 | 09:57 PM
Nealoc187's Avatar
SLOW
Re: i35 performance
That would be because of the advantages of RWD launches I would think...
Old Oct 27, 2001 | 04:04 PM
Tri-lite's Avatar
Re: Re: 2002 mixima 0-100 KM/h ....
Also, the Altima was tested at approximately 6.0 seconds 0-60 and 14.5 seconds 1/4mile. The Maxima isn't too far off those times. [/B][/QUOTE]
96.xx km/h (almost 97) = 60 mhp ..thats a fact... and im estimating .2 or .3 ... cuz i've compared my max being 0-100km/h 7 sec. and 0-60 mhp 6.6 sec.
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Marc2theMax
Sep 28, 2015 08:13 AM
