Who here, has taken out there auto trannys?
Old Mar 30, 2008 | 05:16 PM
Menasor's Avatar
I have to (for the 3rd time) take out my tranny to fix a leak from the rear seal. I have an engine support bar and was curious how some of you use it to support your VQ30DE/K. I have been using the side engine mount (passenger side) and the front engine mount bracket as supporting points for the engine. But would like to support the engine at a 3rd point. Any ideas from you guys would be appreciated. Thanks.
Old Apr 3, 2008 | 02:51 AM
AceofSpds's Avatar
wat
floor jack
Old Apr 3, 2008 | 07:03 PM
Menasor's Avatar
Originally Posted by chopstix2nrz
floor jack
Well, that's usually what I used to support the engine, up until I have to unbolt the oil pans. I was just curious if there is another place I can used a chain and support it at another point on the engine and have the transverse engine support hold it. BTW, thanks for your reply.
Old Apr 3, 2008 | 11:38 PM
AceofSpds's Avatar
wat
What about after you take the trans off, put the upper transfer case bolts that thread into the engine block then run a chain through those.
Old Apr 4, 2008 | 12:35 AM
Menasor's Avatar
Hmmm, sounds like it should work. I have a feeling I am going to be replacing the RMS again and if so; I will give that a try. Thank you so much for your help.
Old Apr 9, 2008 | 06:20 AM
Product_Of_Korea's Avatar
i might have to do this again yay!! i have a 5spd though
Old Apr 10, 2008 | 12:06 AM
CMax03's Avatar
I placed a 2x4 across the strut towers with a chain and you can use coat hangars, bail wire, safety wire, or a jack under the engine ( like a small bottle jack). If you have a garage then a floor jack could be used! If you're in an apt or multi unit dwelling I would leave any thing out cause peoples fingers are really sticky these days!
Old Apr 19, 2008 | 04:54 PM
J kelz's Avatar
Idk What this part called in the manual maxima transmission..
Need help finding out whats this part called in a 85 maxima manual transmission..
http://i233.photobucket.com/albums/e...wet/maxorg.jpg
Old Apr 19, 2008 | 06:32 PM
BenStoked's Avatar
Jesus was a Zombie.
"striking rod" is the bar, and the connection(thingy(real technical, huh)) is the "yoke"
. why do you ask? just curious. was it bent during removal/installation?
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
dshinn
Sep 26, 2015 08:07 PM
