does anyone know how to replace a CV boot?
Re: does anyone know how to replace a CV boot?
Originally posted by VQdriver
i found out i need to replace one of mine. what tools will i need? how much does one cost? thank you for the tips.
Re: Re: does anyone know how to replace a CV boot?
Originally posted by 190hpKiLLA
What is Cv boot? Thank you.
The constant velocity joint boot, huh? I can't take you through the steps, but I think there's a thread on it somewhere. Try the search function. Is the cv joint clicking when you turn? Did a bunch of grease get flung out of the boot? If the cv joint is clicking, you need to have the entire axle replaced, as the clicking indicates a damaged cv joint. You'll get a reconditioned replacement, too. It's par for the course. I think the only folks that get new axles are those who get them replaced under warranty. New axles are really expensive! Good luck.
If the boot is torn, then water and dirt have already gotten into the joint, contaminating it. This will soon lead to the death of the joint. To replace the boot or the joint, you have to have the axle off the car and disassembled.
You can get a replacement axle for pretty cheap (around $110 plus core). But, these will have reconditioned joints wich are done by grinding the joint surfaces back smooth. This grinding removes the hardened surface from the joint, this leads to a quick death. I had some on my car, they only lasted 35000 miles.
I just replaced my passenger side axle with one from www.raxles.com. They use brand new joints and boots and pack them with synthetic Amsoil grease. The axle (which includes the intermediate shaft and bearing) was $170 and included a label to ship the core back.
Could be the best bet for you.
It was a MAJOR pain. Basically, all the stuff around the wheel has to be removed and disconnected to slide the axel out of the transmission... or (in your case) to slide a boot on the end and refill it with grease. They make these split boot things that can be put in place without pulling the wheel assembly apart, but I never had much luck with those things... they always leaked and tore and only lasted a few months.
Originally posted by SSandMaxima
I did this on a Honda once... to pull the wheel off, all the junk including separating the ball joint (required a ball joint fork) , etc, etc.
Re: Re: Re: does anyone know how to replace a CV boot?
Originally posted by mzmtg
It wasnt that bad on the max. You dont have to remove the hub carrier from the control arm. You just undo the strut bolts to let the hub carrier drop down so you can slide the axle out...
boot up
if the boot just ripped (real recently) and you haven't driven in sand or water it is possible to change the boot. if you drive with it ripped its not gonna cause any serious problems but you will need to replace the joint.
i changed both outside boots myself and it wasn't difficult but it was a freakin pain. espessialy the right one with the carrier bairing. if you can't do the labor yourself it is probably best to get a rebuilt axle.
also a good time to switch to synthetic gear oil.
Re: boot up
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
