Is more build up caused in the engine with
Old Aug 29, 2000 | 08:33 AM
The New CLIMAX's Avatar
synthetic oil or reg. oil? Thanks
Old Aug 29, 2000 | 08:53 AM
Jeff92se's Avatar
I'm needing a caw
Dino oil->
Neither oil should cause any build up if changed regularly but in extreme conditions when you ask the oil to perform at/near/past their design limits, dino oil will breakdown sooner than synthetics will. synthetics also have less additives to keep the oil stable so in theory it has less junk to turn into build-up.
Old Aug 30, 2000 | 02:30 PM
Kenneth's Avatar
OG :)
Use
Penzoil clean-engine formula, cheapo.
Synthetics run smoother so I would say less gunk.
Old Aug 30, 2000 | 06:48 PM
ronskal
I've run Mobil 1 since about my third oil change and even though I only have 31K miles on my Max, the inside of my oil filler area is spotless, real nice to see.
I do change my oil every 3K so I'm in overkill mode and I figure Dino oil is a better way to go if you rack up the highway miles(cheaper).
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
97_GXE
Sep 15, 2015 06:47 AM
ballerchris510
Sep 11, 2015 05:29 PM
A32goldylocks
Sep 2, 2015 06:39 AM
