Need assistance with fuel filter!
Old Nov 5, 2001 | 03:18 PM
CoolMax's Avatar
is invisible
http://forums.maxima.org/showthread....threadid=73503
1991 VG.
Can't get the damn hoses off!
Old Nov 5, 2001 | 03:29 PM
Jeff92se's Avatar
I'm needing a caw
The hose is probably pretty "glued" on there. I had to carefully use some pliers and try to "break" the seal by twisting the hose. Be carefull not to damage the hose though. It also might help of the car was warmed up(to warm up the hoses). That might make it easier. You can also try to use a flathead screw driver and pry the hose off the filter(to break the "seal". Good luck.
Try not to smoke during this one.
Old Nov 5, 2001 | 03:35 PM
CoolMax's Avatar
is invisible
Thanks...I'll see how it goes.
I'll try not to smoke...Matt said to drink.
Old Nov 5, 2001 | 03:42 PM
shane's Avatar
You can buy a tool just for taking the fuel filter off,all you do is put it between the hose and filter and close the handles and the hose pops off.Should be able to find this at napa so i heard
Old Nov 5, 2001 | 04:21 PM
DanNY's Avatar
Ad·min·is·tra·tor
yup def twist b4 pulling. a little bit of WD40 in that area might help.
Old Nov 5, 2001 | 05:58 PM
nardo'89SE's Avatar
cut that thang off
i had the same problem and just cut the hose as close to the filter as possible, there was enough slack to connect it again without any problems
Old Nov 5, 2001 | 07:33 PM
CoolMax's Avatar
is invisible
Got it done!
Heated up some pliers with boiling water, poured the rest of the water on the hoses, and twisted vigorously!
Thanks everyone!
btw, my dad said that fuel filters do not need to be replaced...fuel is filtered many times as it is.
My response...there's a filter in there for a reason, and after 10yrs I'm sure it's dirty.
So who's right?
Old Nov 6, 2001 | 05:56 AM
2DMax's Avatar
Sure, fuel is filtered many times, but who knows what shape the tanker is in, the gas station tank is in, or the pump...etc, etc.
A clean filter gives you better milage and a smoothing running engine. I replace my air & fuel filter every year.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
