Tire Size Question! HELP!
Old Nov 8, 2001 | 01:27 PM
Ben4bamaMax's Avatar
O.k. the maxima I bought at the auction has 215 60 16's. Stock rims.
At highway speeds the steering wheel shakes a little and if you lightly hold the wheel it seem s to track a little kind of like it has a mind of its own. It is annoying so I was going to replace them with the Kumho's stock 215 55 16. My question is : isn't a 215 the width of the tread and the 55 the % of the width. Therefore, a 215 on anysize tire/rim should be the same width as any other 215, correct? The tire shop tells me there's a difference in height AND width on a 215 60 vs a 215 55.. I say the 60 is just taller.. Will replacing the cheaper brand (Winston) 60 with the Kumho 55 help with my shaking steering wheel at all ?? I am aware of the known problems others have reported and wondered if maybe that was my problem and not the tires. I had the tires on it balanced and it helped but didn't rid it completely. Thanks!!
Old Nov 8, 2001 | 01:33 PM
Sprint's Avatar
size seems fine.. i think they didn't balance it properly.. or maybe the car was in an accident..
Jeff92se's Avatar
I'm needing a caw
Go to www.tirerack.com for tire size info.
Go here http://www.miata.net/garage/tirecalc.html for tire comparasions
Changing tires may or may not fix your vibration problem.
If you alignment is off or if you wheel/tire is not balance, it will continue to cause your problems.
Old Nov 8, 2001 | 01:44 PM
car wasn't in a wreck. Sprint, when you say the size seems fine do you mean going to a 60 is o.k. to do?
No one still answered my question about the width...is 215 the same on all tires?
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximaham
Aug 20, 2015 10:23 AM
