The tension in my clutch is gone! what happened?
Old Nov 9, 2001 | 10:12 PM
bmxsteve's Avatar
Iwent and started my car tonight, it was really cold- mid 30's and i pushed in the clutch and when i started to let up on the clutch, it has no tension in it, it pops up, but it feels terrible and wont go into gear. do you think i just need to get some clutch fluid? it doesnt spring at all. Thanks for the help!
Old Nov 9, 2001 | 11:33 PM
Jeff92se's Avatar
I'm needing a caw
Either the clutch fluid is a little cold or maybe the grease on the T/O bearing shaft(on the tranny) is a little cold.
Old Nov 10, 2001 | 12:36 AM
Czar's Avatar
Check your clutch reservior. If its empty, then check for leaks along the whole system. My bet is that you'll find your leak right at the slave cylinder. I would get a clutch slave cylinder rebuild kit which will include a seal, a spring, and a boot. I'm guessing that the cold weather caused your clutch slave cylinder seals to contract, allowing your fluid to drain out. After figuring everything out, you'll need to bleed the clutch and you should be good to go.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
