*** Need to know fast! What Amperage is the alternator in my 95SE?
Old Nov 12, 2001 | 01:49 PM
JJW95SC's Avatar
I'm going to have my friends shop swap the bad alternator for me but I need to know what amp. it is 110 or 125.
Thanks!
Jim
Old Nov 12, 2001 | 01:59 PM
maxima42's Avatar
if your car is cali emissioned teh alternator is 110 amps, if not it is 125.
Old Nov 12, 2001 | 02:03 PM
JJW95SC's Avatar
How do I tell if I'm cali-spec or not?
Jim
Old Nov 12, 2001 | 02:07 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Search came up with conflicting answers:
http://forums.maxima.org/search.php?...g&pagenumber=1
Some think it's 110A, while others think the GLE has a 120A to 125A output.....
I would just get the higher rated one.
Old Nov 12, 2001 | 02:12 PM
bill99gxe's Avatar
Jim,
A check with carparts.com's database seems to confirm:
A)95 to 96 models are 110A and 125A for Cali and non-Cali spec cars, respectively.
B)97 to 99 models seem to depend on the model, with 100, 110 and 125A output alternators depending on trim designation......
C)Do yourself a favor and just get the 125A spec one.
Nissan cost-cutting at it's finest.
Sonic's Avatar
Hitachi - LR1125-702 OEM part number:2310031U02R
Nominal Rating 125 A
Ground Polarity Negative
Hot Output Current
Note: Minimum revolution should be less than 1100 rpm under no-load when 13.5 volts is applied.
>36 A at 1300 rpm
>94 A at 2500 rpm
>123 A at 5000 rpm
Minimum Length of Brush >0.2362 in
Brush Spring Pressure 3.60-12.34 oz
Slip Ring Minimum Outer Diameter >1.024 in
Rotor Resistance 2.35 ohms
Old Nov 12, 2001 | 02:21 PM
JJW95SC's Avatar
Originally posted by bill99gxe
Jim,
Bill, getting a higher rated alternator than that which came with the car couldn't cause any problems??? I'm assuming fitment is the same...
Jim
Old Nov 12, 2001 | 02:23 PM
maxima42's Avatar
Originally posted by JJW95SC
Bill, getting a higher rated alternator than that which came with the car couldn't cause any problems. I'm assuming fitment is the same...
Jim
using a higher amperage alternator means that you have more electrical power to run amps, and other electrical components.
Old Nov 12, 2001 | 02:28 PM
bill99gxe's Avatar
Jim
No, it shouldn't. This is Nissan we're talking about, so I'm sure it fits in the same space and bolts on without problems.
Old Nov 12, 2001 | 02:48 PM
tunedup's Avatar
how much are alternators?
thnx.
Old Nov 12, 2001 | 02:55 PM
bill99gxe's Avatar
The one medic spec'd is $215 here:
http://nissanautoparts.com/detail.as...&Submit=Submit
Sonic's Avatar
Re: how much are alternators?
Originally posted by tunedup
thnx.
About 350.
Old Nov 12, 2001 | 02:59 PM
bill99gxe's Avatar
Re: Re: how much are alternators?
Originally posted by medicsonic
About 350.
yeah, i'm surprised at the 215 number from nissanautoparts.com......
Old Nov 12, 2001 | 04:15 PM
Wizeguy's Avatar
$201 according to the partnumber at http://www.nissanparts.cc/ aka Tacoma Nissan.
Old Nov 13, 2001 | 08:31 AM
ericdwong's Avatar
Hot Output Current
>36 A at 1300 rpm
>94 A at 2500 rpm
>123 A at 5000 rpm
Hmmmm, this makes me wonder if the alternator power went down over the years. Where did you get those numbers from? In my 1997 Factory Service Manual, on page EL-40 the alternator specs show 2 different alternators. Part LR1100-711 and LR1110-709. The former is the "standard" and the latter is the "option". The specs are all the same except the output. Standard for "nominal rating V-A (volts-amps) is 12-100 and 12-110 respectively. It does not tell me why there are differences in the alternators, but the only clue i found was on page EL-36, in the system description that says ...power is supplied at all times to alterntor terminal 'S' through: 120 A [For California] or 140A [Except for california]fusible link.....". Thus, it makes me believe that
Also, I remember some time last year I asked the parts dept of the local dealers about the same issue. they told me the part numbers for the GXE, SE, GLEs were the same, thus nullifying the myth that "cars with heated seats have bigger alternators". The higher output appears to be california/non california emissions based.
Old Nov 13, 2001 | 08:39 AM
Sonic's Avatar
www.alldatadiy.com , however, it is a subscription site.
TallTom
57
Oct 14, 2025 05:16 PM
homewrecker
Sep 24, 2015 07:01 PM
