What's the best oil cooler for the buck?
Old Nov 13, 2001 | 11:22 AM
Chebosto's Avatar
RIceD OuT moDErAtor
Im a bit worried about the heat the SC is causing on the oil...
what are the best oil coolers on the market? i know stillen and greddy have them but they're like $400. thats way too much.
what are some cheaper alternatives? thanks
--Cheston
Old Nov 13, 2001 | 11:31 AM
1MAX2NV's Avatar
Re: What's the best oil cooler for the buck?
Sup Cheston. I know a good cheap alternative. Change your oil every 3K miles
--Cheston
Old Nov 13, 2001 | 11:35 AM
1MAX2NV's Avatar
If you really want one, check summit racing. I remember seeing some for like $200.
Old Nov 13, 2001 | 11:59 AM
mzmtg's Avatar
Minister of Silly Walks
Just tape some bendy straws together.
Old Nov 13, 2001 | 12:14 PM
emax02's Avatar
How about B & M oil coolers? Maybe they only make tranny coolers though, I'm not sure.
Old Nov 13, 2001 | 01:06 PM
skimax's Avatar
whats up, you and billy both getting one...
Old Nov 13, 2001 | 01:41 PM
BlkCat
--Cheston
Is your temp gauge needle at the half way point or is it higher?
Mines always at the half way point. I just do oil changes every 3000 miles or so.
Old Nov 13, 2001 | 05:53 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
I told you i was putting together a kit Cheston. Ill show you someday when your back up north. Weather in LA too hot for the blower. Bring it up to Nor Cal weather..much better
oh yea, the temp gauge is for water temp..not oil temp....heeh
Old Nov 13, 2001 | 06:13 PM
Kevin Wong's Avatar
Hayden and Flex-a-Lite are pretty affordable. I'm about to install one myself but haven't decided which one to go with. I think the Hayden has more surface area to volume but both should get the job done. It should lower the oil temp by 20 degrees Celsius or so if I'm not mistaken. My concern was longevity for both the cooler and the engine. I'm convinced this will extend the life of the engine (mainly the internal parts) but I'm not sure if the rubber hoses are favorable or should I try to find some metal or silcone lines?
Old Nov 13, 2001 | 06:18 PM
Turbo95Max's Avatar
you can get SS braided lines. The higher quality kits come with these. ive heard you can extend your oil change intervals because the oil runs cooler therefore doesnt break down as fast.
Old Nov 13, 2001 | 06:36 PM
CoOlKidS1979's Avatar
Check out this site, no prices listed but a big selection, its where I got the peices for the setup Im working on.
perma-cool.com
Old Nov 13, 2001 | 09:39 PM
Screaminfast's Avatar
i remember reading somewhere that jc whitney had oil coolers too. I'm looking over the perma-cool website now, and I like the fan on the cooler idea.
Old Nov 13, 2001 | 09:44 PM
sorry for double post but anyone know what the thread and size of our oil filter is, in case I wanna piece together my own cooler?
i like the permacool Maxi-cool junior ones with the fans, but i want to use SS lines...good fittings....etc.
Thanks guys
Old Nov 13, 2001 | 10:48 PM
Chebosto's Avatar
RIceD OuT moDErAtor
HAHA;
i'm posting for Billy. He lost his .org forum password. i dont want one. but. anyhoo..
Old Nov 14, 2001 | 09:18 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
Id check out the local junkyards, I got a transmission cooler for $5 Its 4 1/2 X 2 X 11.
Old Nov 14, 2001 | 07:22 PM
CandiMan's Avatar
Say Candyman 5 times
At my usual 5K the first time I removed my oil drain plug
After the cooler was installed, the oil seem to look as if it only had 3K on it, so now I'm draining at 10K with periodic checking. I've always used full synthetic oil since the engine had 30K and now I'm at 106+K. The cooler has been in since about 70K. My main concern was pressure drop, because with any type of coolers (air,liquid,etc) a drop will occur. I've already installed a t-fitting with a oil pressure sender but have yet to installed the gauge to keep a eye on the pressure. As someone mentioned, another concern of mine was the deterioration of the rubber hose. To keep the price down, I purchased a Hayden cooler and used rubber hose suited for motor oil. Now, these hose I check more periodic than the oil itself, because the slightest noticeable crack and it's time to change the hose. What really sucks is that I can only see the condition of the OD of the hose and not ID. I used one of those sandwich adapters placed between the oil filter and base which lowered the filter about 2"
Old Nov 14, 2001 | 08:30 PM
1MAX2NV's Avatar
I just looked through my jegs catalog
They have bunch from $70-$140.
Old Nov 14, 2001 | 11:23 PM
Re: I just looked through my jegs catalog
yea I priced most of a system from summit racing....I could probably put one together with the Perma-cool Maxi-cool Six-pass w/ fan, and all hardware, for just under or around 200 bucks. Not bad huh, twice as good and twice as less as stillen's kit....hehe
-Mike
Old Nov 15, 2001 | 07:12 AM
MardiGrasMax's Avatar
The Permacool 250hp cooler fit my max just fine. You even get to switch to a larger oil filter, one from a Ford V8, the stock maxima oil filter is crapy small. It took some creative hose routing, but its fine. Oil pessure is fine also, between 15 & 20psi at idle. For ~$90 its a good deal.
Old Nov 15, 2001 | 10:54 PM
sleepermax's Avatar
Do you notice any difference in performance or driveability?
Old Nov 16, 2001 | 06:53 AM
No difference.
I installed it more as a piece of mind item. Because I'm supercharged and it gets really hot in New Orleans I thought it was a good idea.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
