trans. cooler install ?
Old Nov 14, 2001 | 09:57 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
I was wondering if anyone with a trans. cooler bypassed the stock cooler in the radiator and just used the aftermarket cooler. Is there any reason they say to run both in series.
Old Nov 14, 2001 | 10:18 AM
max95q's Avatar
I wldnt recommend that . I hve one and didnt bypass I still used the radiator and made it go thrgh the radiator first then to the trans cooler to get cooler before returning to the transmission. that way you he cooler fluid going to the transmission.
Old Nov 14, 2001 | 12:19 PM
94Max's Avatar
Route fluid thru aftermarket cooler first, then thru the stock, in-radiator cooler.
Some aftermarket coolers can cool the fluid more than is desired, reducing tranny life. Remember, cool fluid is better than hot fluid, UP TO A POINT. Beyond that, continued reduction of fluid temp is actually detrimental.
In addition, running tranny fluid thru the aftermarket cooler first can take some heat load off the engine cooling system. And this routing provides more consistent tranny fluid temps because the engine coolant temp is more consistently maintained via the thermostat.
Kirk
Excalibur23
Oct 13, 2015 04:33 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
catalinvint
Sep 16, 2015 07:48 PM
2kmaximel
Sep 16, 2015 03:19 PM
