I added installed new endlink bushings. Nice.
Old Nov 14, 2001 | 06:44 PM
Dave B's Avatar
Not DAVEB the parts guy
Today I picked up a set of polyurethane endlink bushings because my stockers were looking a little compressed after nearly 6 years of use. Upon removal, these suckers were chewed up real bad on the inside. I installed them and the sway in turns is noticably flatter and initial turn in is quicker. I plan on getting a set of front sway bar bushings now.
Install is quite simple. Jack up the front. Support the car with jackstands. Take off the wheels. Undo the upper endlink nuts (16-22 ft/lbs) on both sides of the car. Remove the bushing cap and upper bushings on both sides. Push the sway bar up. Remove the lower bushings. Install the new bushings in reverse order. The only catch is you'll have to trim ~1/8th" off the bushings to get them to fit (simple job with a vise and saw). Total install time 30 minutes.
Dave
Old Nov 14, 2001 | 09:59 PM
ericdwong's Avatar
Re: I added installed new endlink bushings. Nice.
Hmmm, I'm payin attention here. Ever since my differential and since I live in the middle of nowhere, I have the itch to do more handling mods. Looks like this will be the first one. Are the endlink bushings just the ones from Addoco at Pep Boys? If so or if not, can you give the make/model anyway? I'm going to do this and the poly front sway bar bushings.
Dave
Old Nov 15, 2001 | 05:19 AM
mzmtg's Avatar
Minister of Silly Walks
I did this too. I used the Addco bushings that are $8 at AutoZone. I had to trim em a little, but well worth the effort.
Old Nov 15, 2001 | 06:33 AM
94Max's Avatar
I've done this mod to a couple of cars over the years. Always very worthwhile.
IMO, any car with more than 50K miles can benefit from replacing any/all rubber bushings with polyurethane equivalents.
BTW, some mfg's use graphite-impregnated polyurethane (call it polygraphite). These are less prone to squeaking. Also, don't skimp on the silicone grease during the installation to help fight the squeaks.
Good Luck,
Kirk
Old Nov 15, 2001 | 03:04 PM
Dave B's Avatar
Yep, there ones from Autozone for $8. Very worthwhile.
Dave
Old Nov 15, 2001 | 03:25 PM
Synki's Avatar
So i am taking it that the stock bushing are rubber right? I have heard that the polyurethane makes the car handle better and hold up better to the weather?
Old Nov 15, 2001 | 04:21 PM
mzmtg's Avatar
That's the idea
Old Nov 15, 2001 | 04:22 PM
mzmtg's Avatar
That's the idea.
Old Nov 15, 2001 | 05:38 PM
ny96max's Avatar
anyone have part numbers from AUTO-ZONE for them??
MaxLife17
Jun 27, 2019 01:37 PM
Bonka
Sep 14, 2015 11:18 PM
Maxie40
Sep 14, 2015 11:28 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
