Anyone Try Repairing a Hanshin Ignition Power Transitor
Old Mar 10, 2009 | 09:19 AM
Edge's Avatar
These are also called ignitor or ignition module and run $100 to $150 new. This is for a second gen but I would think this Hanshin brand would have the similar construction. Power transistors are available from Radio Shack, Allied or Digi-key for a $3-5, so on an older Max it might make sense.
Old Mar 12, 2009 | 10:55 AM
Professor's Avatar
seems plausabile if your comfy with soldering and whatnot/
Old Mar 12, 2009 | 12:52 PM
pmohr's Avatar
No more Maximas...
If you're able to get it apart and stripped down to where you can repair it without destroying the whole thing, then sure, you could do it.
Just have to make sure the replacement part you're buying conforms to the ratings of the OE part, or you may very well be replacing it again in short order.
Old Mar 12, 2009 | 01:06 PM
Matt93SE's Avatar
STFU n00b!
depends on what's broken inside it.
It's usually NOT the power transistor part of the circuit.
Old Mar 13, 2009 | 11:33 AM
Edge's Avatar
What part of the circuit have you found that fails?
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
