Motor probs...
Old Nov 19, 2001 | 12:53 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
Motor probs...
hey, was wondering if anyone can help me out with a bit of a prob.
still no spark in #2 and #3 cylinders. All other cylinders have spark
Coil has 3 wires, Red, black, trigger/signal
Red im reading battery voltage, black has good ground, and trigger on the 2 bad cylinders are about .3 volts. All the good cylinders read about 3 volts. Now what can cause this?
we've already swapped a good coil in, so its not that, swapped the ECU, contiunity between ECU and coil is good. Crank and cam sensor circuits seem fine as well. Im all out of ideas....can anyone offer some help? so close but yet so far...cant drive the stupid car.
Old Nov 19, 2001 | 07:13 AM
mtrai760's Avatar
'Trynna' is not a word
Re: Motor probs...
Email Mardigrasmax, I know he had a bunch of prob's with this. Good luck man...
Old Nov 19, 2001 | 07:14 AM
MardiGrasMax's Avatar
Perhaps the connectors on #2 & #3 harness connectors are not getting good contact?
Perhaps the ECU connections are not getting good contact?
Do you have access to an OBDII scan tool to check the timing signals? And look for stored codes that havent tripped a check light yet?
Worst case your nissan dealer can hook it up the the consult machine to diagnose it.
Did you check the cam timing marks to be sure it was all lined up properly?
Old Nov 19, 2001 | 08:01 AM
Evil Yak's Avatar
haha u sure the nissan dealer will even touch turbo's car?
we were discussing it yesterday, i wonder if theres somebody
we could drop the car off to and have them diagnose it for us...
Old Nov 19, 2001 | 08:53 AM
If you go and talk to the Shop Forman and explain you just want help to diagnose it on the consult machine and you will do the repairs, I dont see why not. My local dealer said they would have done it for me when I had my problems.
Old Nov 19, 2001 | 09:08 AM
Sonic's Avatar
For 75 bucks, why not? It's better than shooting in the dark.
Old Nov 19, 2001 | 11:15 AM
Turbo95Max's Avatar
thanks for the suggestions
well, my friend's shop has a consult, so i can always go there, i have a SnapOn Diagnostic scan tool that i been using.
Not getting good contact could be a possible cause, but when we checked voltage directly out of the ECU it still read .3 volts on the bad cylinders. What can cause low voltage on #2 and #3 only? cant figure it out...
Old Nov 19, 2001 | 12:05 PM
The trigger wire are grounds, I thought? So their should be little t0 no voltage, just good continuity to ground. Isnt their a way to hook a test LED light to the trigger wire and test it for trigger signal. You would hook the LED between +12v and the trigger wire at the coil connector. Then crank the motor and the LED should blink consistantly, do this on a working circut also so you can see what the LED should look like whan it flashes. I think this procedure is in the Haynes manual. If the LED light dosent blink and their is good continuity back to the ECU that points to the trigger signals sent to the ECU from the timing sensors. Either the sensors, REF, POS, CAM, are are not working (but u have checked them) or the signals are out of phase. Out of phase means that the signals from the sensors are being recieved at conflicting times and the ECU dosent know what to do.
1) Try the LED test light thing and see what you get, my bet is weak and/or eratic flickering.
2) Pull off the front valve cover and look to be sure the front cam is in the right spot for TDC on the motor, the front cam has the CAM timing sensore marks attached to it. If its not aligned properly the timing marks are off between the cam sprocket and crank sproket and the sensor signals are out of phase. If you have a spare motor or head to compare the positions for TDC to it helps, the cam sprocket has a mark on ot that shows TDC for the cam. Sounds like this is the problem. To fix it the timing cover has to come off
3) if that still isn't it check for stored codes
4) consult time
5) sell it to me
Good luck!!!
Old Nov 19, 2001 | 10:31 PM
Turbo95Max's Avatar
doesnt sound like good news for me.....wanna make a trade Matt?
give me a tiny bit of cash and a stock motor and this built motor is yours...sound good?
Old Nov 20, 2001 | 06:45 AM
Yea it does sound good, say fi dolla and a stocker?
But I cant do that to ya.
Ya gotta fix it Matthel, just shake off the blues and do it. Its just some time and labor. You got some of that? Push through!!!
Old Nov 20, 2001 | 06:49 AM
dwapenyi's Avatar
You can pull the codes WITHOUT the consult. If there is a code, and your check engine light is not on, just go thru the motions as if your check engine light is on. If there's a code stored, the MIL will blink it at you.
DW
Old Nov 20, 2001 | 08:22 AM
Consult does more than just pulls codes.
DW
Old Nov 20, 2001 | 08:25 AM
Sprint's Avatar
hey matt... you are one smart ****
Old Nov 20, 2001 | 08:35 AM
Well thats better than a dumb ****, right Sprinty?
Old Nov 20, 2001 | 08:47 AM
Sprint's Avatar
well i am always impressed with the vast knowledge of the internal workings and engines of the maxima
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
